| Tags: fault, gearbox, gearbox noise |
| | #81 |
| JCW ON SONG | that noise would be the spigot bearing. when you are stopped at the lights do you leave your foot on the clutch? if so that can wear it out prematurely |
| | #84 (permalink) |
| MINI2 Newbie Join Date: Jul 2005 Local Time: 08:35 PM
Offline | Have had my 05 MCS for two weeks and it almost immediatley developed this noise. Took it to Downtown BMW (Toronto) and they fed me a load of crap saying that it was normal and due to the gear spacing. I brought the car to another dealership, with printouts from this forum, and spoke with the service manager who agreed that it was a dual stage flywheel. It's in there now being replaced and will be ready tomorrow. Hopefully this will solve the problem. Last edited by Acadian : Jul 21st, 2005 at 07:12 PM. |
| | #85 (permalink) |
| Sparkling Silver R56 | I cant believe i found this thread... what a spin! Northandy... mate i had the exact same prob. I tell you my story - bought my car June 04... Rallye Monte Carlo special. after 1 week of owning... i noticed the exact same noise in your description. I took it to a BMW dealership... one that i didnt buy car from just to get an opinion. So the typical thing happened when you take something back due to a technical fault... it wasnt very obvious and loud at the time. The tech said just keep driving it for a while and see how it goes. Anyway so over the next month or so this thing got louder. Took it my dealership... they diagnosed and it was the thrust or throw bearing i think they said. i'm not too tech savvy when it comes to cars... but it had something to do with the bearing that constantly spins and when you press clutch it engages. All front wheel drive cars do this exact same thing... but with this fault it becomes louder as the bearing is damaged. The final conclusion they said the gearbox will have to be replaced.. as its easier than changing bearing. Got the car back... all fixed and well. They said the Bearing was split in half scary stuff. I must admit i spewed about this whole thing. I wrote a letter to Dr Franz Sauter and asked for a new car. he got one of his PA's to ring me and try and calm me down. I didnt back down. I said to her 'lets make a deal... i paid good cash for this car and i want a new car... not one with a gearbox that has been ripped out... if you think the car is good... you keep the car and give me a newy' he heh eh he h. Didnt work But yes its all good now... I also told her i should've bought the Renault Sport 182... cheap BMW product. LOL! Mic |
| | #86 (permalink) |
| MINI2 n00b | Sorry all... late to the party. Is this the noise when pulling away in either 1st or reverse is a sort of higher-pitched grate/whine (not the pwr-steering)? If so, I have such a noise in both my '02 and '04 MCS, sounds like something isn't lubricated, and you can sort of 'feel it' in your clutch foot. If this is what you guys are talking about, could you let me know? The '04 is going in for 10k soon, and the '02 is going to hit 36k before long, so I'd like to get it addressed when convenient/still possible. Many thanks! .:Pauly:. |
| | #87 (permalink) |
| MINI2 Newbie Join Date: Jan 2004 Local Time: 03:35 PM
Offline | gearbox noise hi i work in a dealer and we have no trouble changing gearboxes for that noise and it is the input shaft bearings that are gone.doing them all the time for my customers.it is only the early gearbox that tend to suffer with this noise. ![]() |
| | #90 (permalink) |
| MINI2 Newbie Join Date: May 2005 Local Time: 04:35 PM
Offline | Idle Tranny Noise I think there are a few different noises being referred to on this thread. I believe the original complaint was the gear-lash noise at idle, in neutral. Disappears upon engagement of clutch, because the idler gear is no longer spinning with engine. Theory is that the less cylinders, the less consistent are the instantaneous RPM's, i.e. the tach may register a smooth "avaerage" 700 RPM's, but at any given point on each rotation, immediately after and during a power stroke, for example, the engine is rotating at a considerably higher rate for the early portion of the cycle, then slows towards the bottom of that power stroke as another cylinder is on the compression stroke, and then the cycle repeats. At higher RPM's inertia and the flywheel combine to smooth things out. It is the momentary slight accelerations and decelerations that alternately drive the idler gear then slow down the idler gear that causes the gear to rattle back and forth in the spacing between the gear teeth. My '05 MCS has the problem, so it doesn''t seem this is limited to "early" gearboxes. Did the poster who had the tranny replaced experience an improvement? If so, did they tell you what they changed in the transmissions to cure the problem? |
| | #92 (permalink) |
| only the brave! | My MCS went in about 3 months ago for the same noise as described in this thread, first time they said it needed a new modified flywheel, but when i picked it up all they did was the clutch release bearing, now it is doing it again, so i took it back and they did the clutch release bearing again, noise still there wwhen i picked it up Now they want to test it against another MCS, then if happy they want to fit a new flywheel, but they forgot that thats what they origanally did or supposed to have done. Right, im picking the phone up and demanding new box, clutch, flywheel |
| | #93 (permalink) |
| MINI2 Senior Join Date: Jan 2003 Location: Los Angeles, CA Local Time: 01:35 PM
Offline | During the attempted fixes to my car, they had given me the new flywheel...it seemed to improve engine response and smoothness, but it didn't fix the noise completely as it came back awhile later. The next time the noise came back (with other issues), they said they traced it to a defective clutch plate that was slightly off center. After replacing the transmission with a *new* unit (rather than remfr) and replacing the clutch again, the noise was eliminated. The noise was still cured at the time that my vehicle was finally "surrendered" (lemoned), but that was the longest period of time the car had ever been without the noise (and the smoothest it ever shifted on a somewhat regular basis). Of course whether the fix was the *new* replacement transmission new clutch re-designed flywheel a combination of all of the above ...I'm still not sure of. The drivetrain had so many problems and was taken apart and put back together so many times that I can't (nor really want to) remember the timelines for all of what happened. ![]() |
| | #94 (permalink) |
| MINI2 Newbie Join Date: Oct 2005 Location: Hampshire Local Time: 08:35 PM
Offline | Quick question. Our Cooper S will be having its flywheel replaced shortly due to the noise described in these threads etc.... How long did it take to replace for those people that have had it done (1 or 2 days)? What is involved, e.g. is it a drastic engine out job to get to the gearbox or is there enough space to work in situe? Thanks |
| | #95 (permalink) |
| MINI2 NAM Refugee Join Date: Nov 2004 Location: Los Angeles Local Time: 12:35 PM
Offline | I hear a vibration noise similar to what CalPauly describes. It only appears the moment I let the clutch out and accelerate in first gear. Almost always when the car is cold, sometimes when warm. My flywheel was replaced last summer, less than a week later the noise reappeared. Last visit I was told MINI was aware and working on a fix, not to worry because it wasn't serious enough to disable the car (just make it sound like a cheap piece of crap, thanks BMW!) and that since it was documented I would get a fix when they figure it out even if my warranty has expired. I feel like I'm getting the brush off especially since many others with different clutch/noise experiences are being told the same thing. I struggle daily with whether or not to sell the car, I just can't imagine the value holding much longer when year after year these cars are sold with the same problems. Cute and fun only goes so far....... I can't stop driving.... |
| Gearbox/Clutch Noise? | nikkib0645 | MINI Cooper | 3 | Jun 2nd, 2007 12:31 PM |
| Poss. different gearbox noise | mph999 | 2nd Gen Faults & Fixes | 8 | May 12th, 2007 03:00 PM |
| Gearbox noise | STU56 | 2nd Gen Faults & Fixes | 13 | Apr 6th, 2007 11:03 PM |
| gearbox noise cooper s | mowgli uk | Engine & Drivetrain Tuning | 3 | Jun 29th, 2006 11:02 AM |
| Mini Cooper 2005 Gearbox Noise | morrisonj | MINI Cooper | 1 | Sep 10th, 2005 07:24 PM |
