| Lo Scoglio Join Date: Jan 2004 Location: tuscany M.Argentario Local Time: 04:29 AM
Offline | rattle around 5.000RPM I check already in FAULTS & FIXES but I did not found anything similar,i guess,anyway this is my problem: around 5.000RPM in 2nd gear in acceletion or in deceleration I can clearly ear like a rattle noise caming from the engine,it seems like it comes from the exaust.nobody had the same problem??Thanks |
| MINI2 regular Join Date: Dec 2003 Location: East London Local Time: 03:29 AM
Offline | It's probably the exhaust heat shield... mine did this yesterday. Don't worry it's easy to sort out.... Open the bonnet and have a look.... it's the silver aluminium foil thing under the brake fluid and power steering reservoirs above the exhaust manifold. Give it a tap with your fingers. If it just makes a hollow noise, sort of like a drum it's probably ok. Mine was hitting something underneath and when you tapped it, it hit something else making a metallic clank sound. I fiddled about and bent it a little.... no metallic noise when you tap it... and silence when you accelerate;before there was a rasping, zinging sound on acceleration, both at the top end and when pulling away, a bit like having a hole in the exhaust.... now all cured. |
| Rattle rattle rattle | sarachryan | 2nd Gen MINI Cooper | 29 | Feb 22nd, 2007 11:40 AM |
| Another new rattle..... | NED | Faults & Fixes | 1 | Apr 17th, 2003 11:12 PM |
| rattle | mini_coop_her | Faults & Fixes | 13 | Feb 26th, 2003 02:24 AM |
| Rattle, rattle, rattle | chapjoe | Faults & Fixes | 2 | Oct 29th, 2002 06:06 PM |
| Rattle | INDY | Faults & Fixes | 3 | Sep 19th, 2002 06:32 PM |
