Mini Pirate
Old Mar 10th, 2004, 07:20 PM   #1
Nemuri
Nemuri's Avatar
Local Time: 11:29 PM
Uphill On MCS
I was going up a 35 degree hill on 2nd gear going around 20 mph. I then let go of the gas for a split second and engaged it again after which my car seems to have lost power and I started going around 7 mph even with gas fully depressed. Is there something wrong with my car? I have a Feb/March 2004 built.
Old Mar 10th, 2004, 07:42 PM   #2 (permalink)
Paul
Trained Monkey
Paul's Avatar
Local Time: 12:29 AM
What kind of revs did you drop down to?
Old Mar 10th, 2004, 09:04 PM   #3 (permalink)
Nemuri
Nemuri's Avatar
Around 1500rpm and it wants to stall.
Old Mar 10th, 2004, 09:15 PM   #4 (permalink)
SFJAMES
Local Time: 03:29 PM
1500 is a bit low, I keep @ at least 2500rpm going up hills. Its a small 4 cyl. motor on!
United States View SFJAMES's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Mar 10th, 2004, 09:27 PM   #5 (permalink)
Nemuri
Nemuri's Avatar
The problem is that even when I floor the pedal it only goes to 1500rpm.
Old Mar 10th, 2004, 10:00 PM   #6 (permalink)
SFJAMES
you have to downshift, maybe stay in second gear. From a stop try going up the hill in 1st gear, wait till you get to 3500rpm and then change to second. The mini is a heavy car, you might be losing to much foward momentum between gear changes. Does this sound like something you might be doing?
Old Mar 10th, 2004, 10:36 PM   #7 (permalink)
Nemuri
Nemuri's Avatar
I think I maybe losing some momentum. I will try different things and let you guys know. Thank you for all the replies.
Old Mar 10th, 2004, 10:54 PM   #8 (permalink)
SFJAMES
There you go man, when Brutus was new, I noticed it lost a lot of momentum when going up hills here in San Francisco. It will eventually loosen up a little a bit and be more easier to drive up hills. also know that the supercharger is not helping with anything below 2000rpm. motor on!
Old Mar 11th, 2004, 03:03 AM   #9 (permalink)
wmd
wmd's Avatar
Local Time: 05:29 PM
Unhappy Traction control doing its job
That happened to me twice just after I got the car. I was in a similar situation, on a dirt road, going up a steep hill, around a corner with a washboard surface. The traction control will stalemate you every time in those circumstances. The more you apply the throttle, the more wheelspin you get, and the more the ASC or DSC cuts the gas and brakes the spinning wheels. The only way out, is to apply the handbrake, shift into 1st, switch OFF the ASC and then release the handbrake and continue on.
Now, anytime I approach a steep hill on a dirt road, I will have already switched off the ASC. The only feature of the MINI I absolutely hate is the manatory ASC on an MCS in the US--much to intrusive for my tastes. I would have ordered my car without if only it was possible.
Revving when at stand still - normally uphill sarachryan 2nd Gen Faults & Fixes 5 Mar 8th, 2007 11:37 AM
Uphill Clutch Problem Kinster General Discussion 4 Nov 4th, 2003 11:35 PM
Slippijng when park downhill/uphill minifishfish Faults & Fixes 7 Jul 7th, 2003 12:20 AM
MCS, JCW MCS Hartge MCS review Adriann001 MINI in the Media 15 Apr 11th, 2003 06:57 PM
Using CVT on Uphill/Downhill: Which mode to use?? elmadi CVT & Automatic 8 Jan 11th, 2003 11:00 PM
