Old Aug 18th, 2004, 11:37 AM   #1
disdis
disdis's Avatar
Local Time: 08:05 PM
Fan noise after engine turned off??!
sometimes when i turn off ignition, there is a very loud noise (like the radiator fan) running in the egine bay.
this lasts for several minutes b4 it turns off??
it hasnt happened b4.
anyone know whats going on? (i hv a 03' MCS, manual air con)
Hong Kong   Reply With Quote
Old Aug 18th, 2004, 11:44 AM   #2 (permalink)
Martin L
MINI defector
Martin L's Avatar
Local Time: 11:05 AM
All modern cars do this
The engine sometimes still needs cooling after you've parked up, so it will still run the fan so that the engine doesn't overheat
MINI, RX8 and MX5 - Done those............. It's now TTime
Unofficial MINI2.com bean counter
England Male View Martin L's Astro Black & Body Color 2nd Gen MINI Cooper Profile   Reply With Quote
Old Aug 18th, 2004, 11:48 AM   #3 (permalink)
speedos
Local Time: 10:05 AM
Wink
Perfectly normal - will switch off after a few minutes... just means that u have driven the car as u shuould hence needs a little cooling off before sleeping!
Old Aug 19th, 2004, 04:23 PM   #4 (permalink)
mainevent212
i'm new here, but not new w/ the mini or other cars, i've had mine for 2 years almost and it's always been plagued with stupid problems. Most recently, the hatch (boot i think is what everyone else calls it) rattles horribly. and now i have this issue...the fan, stays on after i drive...that's usually normal to me as i do drive slightly hard. but the last 2 times have been different. The last 2 times, it's nearly drained the battery, and the LAST tiem it completely drained it. My fans stayed on apparently so long that it killed the car...anyone know what this could be? because as of right now it's my only form of transportation and i'd like to be able to drive
Old Aug 19th, 2004, 05:24 PM   #5 (permalink)
Malin Dixon
Malin Dixon's Avatar
Some others have had this problem. The thermal switch that decides the fan should be on has failed.
It's not a difficult thing to fix. Until it is fixed, disconnect it when leaving the car.
Malin
United Kingdom View Malin Dixon's British Racing Green & Body Color 1st Gen MINI One Diesel Profile   Reply With Quote
Old Aug 22nd, 2004, 12:48 PM   #6 (permalink)
disdis
disdis's Avatar
so am i rite in saying that if the fan turns off itself after say 1 minute, then its perfeclty normal??
Old Aug 22nd, 2004, 04:04 PM   #7 (permalink)
sjbartnik
Local Time: 06:05 AM
Yes that is correct. In other words, the fan running when the engine is off is completely normal, right up until the point where it is no longer normal
If your fan runs on for a few minutes and then shuts itself off in a reasonable amount of time, no worries.
If however your fan stays running for a period of hours and drains your battery, not normal.
Sean Bartnik
2003 MINI Cooper S
United States View sjbartnik's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 22nd, 2004, 11:16 PM   #8 (permalink)
IML337
saving the world
IML337's Avatar
Australia View IML337's Dark Silver & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 26th, 2004, 10:23 PM   #9 (permalink)
zied
03 MCS Pure Silver / Blk
zied's Avatar
Local Time: 03:05 AM
Send a message via ICQ to zied Send a message via Yahoo to zied
Mine has done this on and off since last November. Strange thing is whenever I drive it to the dealership ( 1.5 hours away) it always fixes itself. I got real use to unplugging it every time I stopped (I rarely drive it long enough or far enough for it to go on... especially in November & December from the driveway to the garage when only 50 degrees outside).
I recently had the expansion tank replaced because of it leaking. Since it was replaced, I know longer have the problem. But I won't consider it truly fixed until it goes through another winter.
Visit Northern California's Redwood Empire Mini Enthusiasts
United States Male View zied's Pure Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Fan noise kimbo80 MINI Cooper S 4 Mar 15th, 2007 06:15 PM
Whining Heater Fan Noise?? MINNOW Faults & Fixes 0 Nov 18th, 2005 06:48 PM
loud fan like noise from engine after turning ignition off aquaanox Faults & Fixes 6 Apr 19th, 2005 03:19 AM
Fan noise - they must fix it surely? DaveN Interior & Ice 1 Oct 2nd, 2003 05:15 PM
Engine turned off + key out = engine still ON! CooperLuv Faults & Fixes 9 Aug 23rd, 2003 07:20 PM
