Old May 21st, 2002, 10:50 AM   #1
brez
Local Time: 08:35 PM
fix for dashboard rattle?
have 1200 miles on new mini and love it. but when turn heat on, dash rattles. i know i'm not unique in this but does anyone know the source or cure for rattle?
Old May 21st, 2002, 03:20 PM   #2 (permalink)
erazo
erazo's Avatar
Local Time: 06:35 PM
Send a message via Yahoo to erazo Send a message via Skype™ to erazo
Check the ducting leading to the glove box. Airflow or temp change could cause loose fitting to vibrate. Just a guess.
United States View erazo's Dark Silver & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 21st, 2002, 04:30 PM   #3 (permalink)
John24
Local Time: 01:35 AM
i've had this exact problem . the dealer told me that it is two parts of the dash board knocking together , to fix it all they did was put some padding in between . the problem has now gone away .
get to your dealer and they should fix it straight away .
Old May 21st, 2002, 07:57 PM   #4 (permalink)
brez
thanks
thanks for the feedback. despite the problem[growing pains] i am thrilled every time i drive this car. and it seems to getr faster every day. thanks again.
Old May 22nd, 2002, 04:05 AM   #5 (permalink)
Phil Craddock
MINI2 Sponsor
Phil Craddock's Avatar
Local Time: 02:35 AM
I've had a rattle on the dash where it meets the 'screen. It all started after my dealer refitted the 'screen and now they have tried 3 times to refit the 'screen and cure the problem
I am picking the car up today from them as they have had it for 7 days to do a few repairs so fingers/toes/crossed I am hoping that everything is OK
Crazy Phil aka The Pirate
United Kingdom Male View Phil Craddock's Pepper White & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 24th, 2002, 04:55 PM   #6 (permalink)
MiNiGuY
topper pad
Sounds like the topper pad (the soft top part of the dash board) where it meets the plastic part of the dash midway. I've done a post on this before to explain the rattle.
Try "topper" in search to read the thread.
Your screen has been changed three times ??
Sure your dealer isn't pulling your leg?? Screens don't rattle and if he thinks they can he shouldn't be near your car!!
What's he doing - taping them on ?!!
England   Reply With Quote
Old May 27th, 2002, 03:54 AM   #7 (permalink)
Phil Craddock
MINI2 Sponsor
cheers MINIGuy I'll do a search for topper.
Yes, each time they have had the car, which is now 3 times, they have taken the screen out and refitted it or thats what they tell me, it is a rattle/squeek/scratching noise that is coming from the corner post where they glass meets the plastic trim and "topper" panel.
I have now stuffed some fabric material into any gaps that I have found to deaden the noise, as the tooper panel does not fit flush to the glass on the drivers side but it still rattles/squeeks/scratches.......and is taking the enjoyment out of the car. So a stongly worded letter is called for as they are now not answering my phone calls
Old May 27th, 2002, 06:27 AM   #8 (permalink)
MiNiGuY
panel
The plastic top panel that you mention should not be flush to the glass at any point. If it is touching the glass somewhere then that'll be the problem. This would be caused by incorrect dashboard fitment. This is not as drastic as it sounds and is easily rectified. Well then again with your dealer.....
No really I think i'm being a bit unfair. The dealers do know their stuff mostly and i'm sure yours is no exception.
They are obviously trying very hard for you.
One thing, at least you probably hold the record for the most MINI screen replacements in the entire world!!!
I do hope your car is to your satisfaction soon.
Old May 27th, 2002, 06:54 AM   #9 (permalink)
Phil Craddock
MINI2 Sponsor
Cheers MINIGuy,
I'm going to call my Dealer and talk to them agin, so hopefully I'll get ot sorted soon.....I'll keep ya all posted on any outcome
Old May 30th, 2002, 08:26 AM   #10 (permalink)
MINI Division
Re your dashboard rattle
I’m with MINI Division. I’m sorry to read about the rattle in your MINI. If you want our hepl, please give us a call at (866) ASK MINI.
MINI Division Customer Relations
Old May 30th, 2002, 09:07 AM   #11 (permalink)
Phil Craddock
MINI2 Sponsor
MINI Division
thanks for your concern. I have just had a call from my dealer and they have done some digging to find the problem and they believe that they could have found something so my Cooper is going back to them next week for them to have it for 2 days and thoroughly check it over, remove and replace parts if needed.
They do sound very sincere that they want this problem solved, which is nice so I am slowly convincing myself that I will have a rattle/squeek free MINI very soon...........
Old Jun 14th, 2002, 01:00 PM   #12 (permalink)
Phil Craddock
MINI2 Sponsor
Big shout for Sytner/Leicester
Just got the Cooper back from Sytner/Leicester after my trials and tribulations of rattly dash.
They took the Topper panel off the dash, placed/replaced a felt panel strip underneath, took the roof lining off and repositioned and touch wood, everything seems fantastic and as new so a big thank you at last to my dealer for getting it sorted and I think they may have learnt a thing or two about this potential problem.
Also my car has had a squeeky drivers seat, but that didn't really bother me, but lo and behold they have cured that as well so again thanks guys
I can now drive off into the sunset and only hear the roar of the engine as it is meant to be and start enjoying the car again.
Old Sep 3rd, 2002, 12:58 PM   #13 (permalink)
LMB
Toon Toon..
LMB's Avatar
<div><a href=
Re: Big shout for Sytner/Leicester
Phil did this stop the creaks/rattles that you hear when the heater is on?
Global Moderator
England Male View LMB's Thunder Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Sep 5th, 2002, 03:42 AM   #14 (permalink)
Phil Craddock
MINI2 Sponsor
Re: Re: Big shout for Sytner/Leicester
LMB, yeah it sure did The only rattles I have now are when I put CD's in the passenger door pocket and they move about when bombing around corners
Dashboard rattle fixed itself up! DeadCanDanceR Faults & Fixes 4 Jun 20th, 2006 07:45 AM
rattle under dashboard tendons Faults & Fixes 16 Sep 3rd, 2003 05:23 PM
dashboard rattle brycem Faults & Fixes 7 Feb 16th, 2003 11:52 AM
anyone have a dashboard rattle fix? brez Faults & Fixes 6 May 22nd, 2002 03:46 PM
Dashboard rattle J.N. Faults & Fixes 1 Apr 22nd, 2002 04:19 PM
