| MINI2 Newbie Join Date: Aug 2003 Local Time: 04:34 PM
Offline | Won't start, lights blink Strange one this morning. My '04 Cooper S won't start. When I try to start the hightlights (the Xenons) and dome light blink on and off, the driver's door indexes down about an inch with each blink. The car was just serviced Friday - first oil change and inspection. The dome lights were bright, suggesting its not a battery problem but the car has a history of have a flat battery on 4 different occasions. MINI Service previously attributed this to a large parasitic drain coming from my after market CD changer ;-(. This is a new problem / symptom since removal of said CD changer. Is it possible for a MINI to act like this if the battery was border-line. Still enough life in it to run the dome lights but when asked to engage the starter motor, all h*ll break loose? Any ideas? I called my local MINI service and got an answering machine, arghhh. Thanks for the help,, Dave Guard '04 Cooper S, 11,700miles |
| MINI2 Senior Join Date: Apr 2004 Local Time: 08:34 PM
Offline | Yes, dead batteries can do all sorts of things but even a virtually flat one will manage the lights for a bit. There is a solenoid that operates the starter motor. If the starter causes the voltage to drop very low, the solenoid will turn off, so the starter turns off, so the battery voltage recovers, so the solenoid turns on, etc etc The result is 3 ish clicks per second with everything electrical misbehaving in sympathy. If you've flattened a battery a few times it may now be damaged and time for a new one. |
Offline | So yes, I called MINI roadside service last night. I didn't have time to mess with it during the day yesterday due to work priorities. I posted here becuase I got an answering machine at MINI Service department. I was hoping for some advice on how deal with the issue now that's in the service department. I don't want them simply charging the battery and returning the car. Its happened before with and without my aftermarket CD changer. They blamed my CD changer because it wasn't made by MINI. Its not in there now and hasn't been for a number of months. Yes, its cold 2F (-17C) here in Cincy right now but the car is inside overnight and recently sat for 9 days and restarted just fine. The dome light in the boot was pulsing while the tow driver fiddle with the tow hook. He was kinda amused by that. Again, the driver window was creeping dow with every pulse. Thanks for the help, Dave |
| Air con on the blink??? | CapeTownDre | General Discussion | 0 | Dec 18th, 2006 09:49 PM |
| Blink the 3rd brake light? | nulltty | Exterior | 4 | Apr 8th, 2003 08:58 PM |
| Full blink from turnsignals? | chiph | Exterior | 7 | Jan 16th, 2003 03:22 AM |
| Won't start.......................NOT cold start issue | Rwatts4mini | Faults & Fixes | 1 | Aug 8th, 2002 11:35 PM |
| Will not start period....NOT Cold Start Issue | Silly | Faults & Fixes | 31 | Aug 5th, 2002 02:35 PM |
