Performance Torque
Old May 25th, 2005, 12:25 AM   #1
Benoit
Local Time: 06:11 AM
United-States clutch pedal
[color=Yellow]My 2005 cooper sometimes doesn't return the clutch pedal all the way. Instead it stop halfway and I have to retrieve the pedal manually.
The dealer is telling me that BMW has issue a technical bulletin ( m23 200 05 ) regarding that very problem. As of now they have not figure out how to fix it.
Old May 25th, 2005, 01:30 PM   #2 (permalink)
holdenontoit
lost in the ozone again
holdenontoit's Avatar
you seem to be all alone on this problem. If it were happening to me I would be doing some diving into the foot well to try to see what any part of the assembly was rubbing and where.Of immediate suspicion would be a floor mat that had somehow slid over to make contact with the assy. somewhere.Next would be the armature below the pedal where it goes through the floor.You may well have to jack up the car and do some creeper surfing with someone in the car depressing the pedal from the inside to see what may have come into contact with the assembly .there is probably some kind of return spring although I'm not sure if it's external or internal.If internal and you car is still under warrentee, go back to the dealer and get it fixed .If out of warrentee and only as a last resort ,install your own return spring if it's part and parcel of a problem at the clutch and you're out of warrentee, it's about $1500 to fix. Good luck.
Old Apr 18th, 2007, 05:27 PM   #3 (permalink)
benlaw78
Local Time: 10:11 AM
Yellow Cooper
Same thing happened to me. It got worse to the point were it did not come back up at all. Needless to say it was the master cylinder
Old Apr 23rd, 2007, 12:50 PM   #4 (permalink)
rakh1
You gotta love the toys!!
rakh1's Avatar
Local Time: 11:11 AM
Quick question - did you try leaving the car and then coming back a while later? I just had a new clutch and gearbox and 3 days later the clutch pedal dissapeared the same yours did - first half way and then eventually all the way to the floor. I left the car for 45 mins and when I came back the pedal was up again and working.... The dealer has not got a clue what might have gone wrong....
Rich
Mini One with *lots* of toys...
http://rakh1.blogspot.com
http://homepage.ntlworld.com/richand...mini/index.htm
MINI2.COM Stickered up
United Kingdom View rakh1's Chili Red & Body Color 1st Gen MINI One Profile   Reply With Quote
Old Apr 26th, 2007, 02:49 AM   #5 (permalink)
roni
try to re bleed the clutch slave cylinder
Clutch pedal squeak IH1 Faults & Fixes 2 Aug 14th, 2007 06:32 PM
clutch pedal grind Gr1zzLy Engine & Drivetrain Tuning 6 Aug 11th, 2006 08:22 AM
Clutch pedal hight Richy777 Faults & Fixes 5 Apr 1st, 2006 09:58 PM
Clutch pedal not returning JamesWhelan Faults & Fixes 5 Nov 21st, 2004 04:42 PM
clutch pedal vibration when ingaging and disingaging pedal S-Cooper MINI Cooper S 1 Oct 21st, 2002 12:50 AM
