Old Jun 8th, 2005, 02:09 AM   #1
VWY
Bill Brasky
VWY's Avatar
Local Time: 03:27 PM
Germany Driver door will unlock and lock only manually, with key only
The only way to unlock or lock my driver door is manually with the key. The toggle switch unlocks and locks only the passenger side door. The remote will not affect the driver side door, either. I really am sick of putting up with my dealer, so any suggestions on what I could myself do would be greatly appreciated.
Thank you so much.
Spain Male   Reply With Quote
Old Jun 8th, 2005, 05:23 PM   #2 (permalink)
CoryB
CoryB's Avatar
Local Time: 05:27 PM
Sounds like the lock actuator solenoid has died or the linkage has come unhooked. You could replace it yourself, but you'll likely have to purchase the part (if needed) from the dealer.
First order of business would be to remove the door card (panel) and have a look.
His - 04 CR/W MCS
Hers - 05 BEP/W MCS
Drivers door central locking - won't unlock - will lock quigger Faults & Fixes 4 Oct 10th, 2007 05:43 AM
Driver's side door won't lock/unlock properly MightyBoognish Faults & Fixes 1 Sep 20th, 2007 03:41 PM
Driver Side won't lock/unlock using "remote/fob" archpopoy Faults & Fixes 3 Nov 25th, 2005 12:38 AM
lock-unlock-lock-unlock-by itself oldcrow Faults & Fixes 4 Jun 2nd, 2004 07:13 PM
Problem with driver door/lock Lisa Faults & Fixes 2 Jan 15th, 2002 01:53 PM
