| MINI2 Regular Join Date: Jul 2005 Local Time: 02:39 AM
Offline | Horrible noise at slow speeds (from wheels) Hi People! I put a post on here a few days ago about my Mini Cooper making strange noises when travelling below 10 MPH. It is like a rubbing noise when the wheels rotate. When I took it to the Dealer, they said there were reports from Goodyear that in the heat, the tyres expand and rub (on something, not sure what!) It has been much cooler the past couple of days, and the noise seems to have gone. Has anybody else had this issue?? My initail concern was wheel bearings. The noise is worse when I've been on the motorway, which makes sense I guess with the tyres getting warmer. Please let me know if there are any similar experiences??? Thanks! Dean |
| MINI2 Regular Join Date: Apr 2005 Location: Northern Vermont Local Time: 09:39 PM
Offline | Dean -- I had a very similar experience last week. It turned out to be a piece of road gravel stuck between the front brake rotor and the dust shield. Once I popped the wheel off it took about five seconds to solve the problem. Sorry if this already occurred to you; I tend to start with the basics. Pete |
![]() Hitched to Mrs H | I've had a funny grinding sound at below 5mph since doing a run up in Yorkshire in May. Haven't been able to identify what it is having had all four wheels off the ground and giving them a spin. Doesn't seem to have caused any problems though and it's not especially loud. I can only hear it if the radio is off and I try and listen for it. D-lite-full |
| MINI2 Regular Join Date: May 2004 Location: Chicopee, Ma Local Time: 09:39 PM
Offline | I was told it is the Good Year runflats. The get noisy after 23K. I'm runnin 17 inch S-Lites with the Good Year All Season runflats. It a rubbing sound, sub 15 MPH. It doesn't get louder with higher speed..rules out a bearing. Applying Brakes does nothing (while maintaining speed)...rules out discs/calipers/pads. When I change tire if It doesn't go away I'll look further into it. Paul |
Offline | Hi There! Yes please let me know how you get on. For now, mine has stopped But it stopped before and came back again! Maybe could be varying tyre pressure with changing tempratures? What do you think? Cheers, Deano |
| | #7 (permalink) |
| MINI2 Newbie Join Date: Sep 2002 Location: Ooop North Local Time: 01:39 AM
Offline | I had the same thing with 16" Goodyear runflats on a Cooper at 18k. A rubbing/grinding type of sound from the fronts when crawling along. The dealer said that this is a know issue with the run flats as they wear. The cure apparently is to remove the tyre and rotate it 90 degress and refit. Go figure. I've just replaced the Goodyears with Pirelli Eufori and the noise ha gone. |
| | #8 (permalink) |
| MINI2 Regular Join Date: Aug 2004 Local Time: 02:39 AM
Offline | Yes it is def a tyre issue, i had the same on my Cooper. They removed the tyres, greased the edges and refitted perhaps a different way round I don't know but the noise disappeared. However this was only after I got the old "oh they all do that " story from my dealer and then I complained direct to Mini who got the dealer to look at my car again. Seems to be a known problem. |
| slow speed noise | deskee | Wheels, Tyres & Brakes | 4 | Oct 11th, 2006 06:53 PM |
| GTT CAI Noise vs Stock at Motorway Speeds ? | Perm | Engine & Drivetrain Tuning | 5 | Jan 14th, 2006 10:49 AM |
| PLEASE HELP!?Noise from wheel at slow speeds | deano_54321 | Faults & Fixes | 5 | Jul 22nd, 2005 03:56 PM |
| Large Wheels = Slow Ride...take it easy. | VWY | Wheels, Tyres & Brakes | 0 | Jun 27th, 2004 06:39 AM |
