Old Jul 17th, 2005, 03:51 PM   #1
Ian Clark
Ian Clark's Avatar
Local Time: 06:19 PM
Send a message via MSN to Ian Clark
Something wrong with my ABS
There would appear to be something wrong with the ABS on my Cooper. (I do have DSC/ASC+T)
Prior to getting my tyres changed I noticed some oddness. At first it was only when I hadn't driven the car for a couple of hours however, now it happens at any time.
Basically, I can be approaching a junction or set of lights at speeds as little as 10mph. When I tap the brakes to stop, the ABS is kicking in, making the car lurch and then applying normal brakes which brings the car up short.
The first time I thought it must have been loose stones or a patch of oil but having experienced this almost every time I go out in the car and at numerous different junctions, it's obviously something with the brakes or ABS module.
Anyway since getting my tyres changed (to non Run flat Toyo Proxes), the Run flat indicator keeps on coming on if I corner hard drive over a small hump or dip in the road. Ok, I know the sidewalls on the Toyo's are a hell of a lot softer than the RF's so I can appreciate the RFI might come on - EVEN though, I've reset it numerous times and checked ALL 4 tyre pressures (of which are all at 32psi)
The worrying this is that each time the RFI light comes on, the ABS light comes on as well and my ABS is deactivated. Found this out when I locked up both fronts. (There's nothing in the manual that states this is normal)
Also when starting the car, the ABS light comes on as normal but stays illuminated (as well as my warning light on tach) until I've actually started moving.
Any Ideas?
PS. I am booked into BMW on Tuesday
United Kingdom View Ian Clark's Pure Silver & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Jul 17th, 2005, 04:38 PM   #2 (permalink)
Mike Edwards
Mike Edwards's Avatar
Pedal position sensor?
England View Mike Edwards's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 18th, 2005, 05:28 PM   #3 (permalink)
Dogtanian
Muskehound
Dogtanian's Avatar
Send a message via MSN to Dogtanian
Probably one of the wheel speed sensors is faulty or even dirty.
They control both the ABS/DSC and the flat tyre light so seems quite likely.
Phil
United Kingdom Male View Dogtanian's Pepper White & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 25th, 2005, 12:33 PM   #4 (permalink)
Ian Clark
Ian Clark's Avatar
BMW have checked the car out and have advised the Pulse Generator is shot and needs a complete replacement plus they have to check ALL of the wiring as the ABS has completely failed.
Old Jul 25th, 2005, 12:39 PM   #5 (permalink)
minicabrio
sick note
minicabrio's Avatar
I had this problem on my convirtible....turned out to be a faulty nearside front abs sensor...
United Kingdom http://www.mini2.com/forum/Visit my Blog at the Motorcade Male View minicabrio's Space Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Was this the ABS? LizzyG Wheels, Tyres & Brakes 14 May 17th, 2007 08:32 PM
Abs? OllyH Wheels, Tyres & Brakes 5 Mar 23rd, 2006 08:45 PM
Abs tuscan_thunder Engine & Drivetrain Tuning 3 Feb 26th, 2004 02:41 PM
ABS lockup newminimark Faults & Fixes 3 Sep 7th, 2003 06:01 PM
Abs,,,,, Marts General Discussion 1 May 26th, 2002 07:26 AM
