Visit Mini Mania UK
Old Aug 23rd, 2005, 01:26 PM   #1
COLUMBO
Local Time: 12:27 AM
Unhappy Problem Gearbox!
My MINI Cooper is a 2003 model. Its done just under 10000 miles with full service history. But it now has problems selecting reverse. Will a new gearbox help?
United Kingdom View COLUMBO's Pure Silver & Body Color 1st Gen MINI Cooper Profile   Reply With Quote
Old Aug 24th, 2005, 08:55 AM   #2 (permalink)
TonyM
TonyM's Avatar
Hi and welcome to MINI2
What sort of problems are you having?
It is quite common for there to be a "crunch" when selecting reverse. It helps to put it in first gear before selecting reverse or to pause between pressing the clutch peddle and selecting reverse.
Is this what you are experiencing or something more alarming?
United Kingdom Male View TonyM's Mellow Yellow & Black 2nd Gen MINI Cooper Profile   Reply With Quote
Old Aug 25th, 2005, 09:36 AM   #3 (permalink)
COLUMBO
United-Kingdom
No there is no crunch when it does go into reverse. It just won't select the gear. Its as if there is something blocking the selector. The garage thought it was the clutch, and they replaced it. But the problem still persists.
Its going back to the garage on the 23 august for a bloke from BMW to look at it. But I'm still convinced its the gearbox selector.
Old Aug 25th, 2005, 10:41 AM   #4 (permalink)
Mini Me GB
Mini Me GB's Avatar
Question
I don't mean to hijack this thread but as it's related I hope you don't mind..
I have an '05 model and always put it in first before reverse to stop it crunching.. My sisters '05 constantly just won't go into reverse unless you select neutral disengage the clutch reengage the clutch and then select reverse.. You know it isn't in reverse because if you try driving it makes a terrible noise and doesn't move..
Took it to the dealer today and they basically said they won't even bother looking at it because it's a known problem.. Personally I think the normal gear crunch that I get is the known problem not a gearbox that won't go into reverse..
United Kingdom Male View Mini Me GB's Laser Blue & White 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Aug 25th, 2005, 11:15 AM   #5 (permalink)
Eelke
I've had more or less the same with the loaner '03 Cooper I had. Often, it would not get into reverse, only making a slight grounding sound when trying to reverse. Depressing the clutch and firmly putting the stick into reverse again would then help. (But trying to do it firmly in the first place never helped).
Incidentally, my current Peugeot has developed the same problem. Maybe it feels it's going to be replaced by a Mini soon and tries to show it's exactly the same...
Netherlands Male View Eelke's Space Blue & Silver 1st Gen MINI Cooper Profile   Reply With Quote
Old Aug 26th, 2005, 09:15 AM   #6 (permalink)
jasonfields007
jasonfields007's Avatar
Send a message via MSN to jasonfields007
My Cooper always did this. Take your foot off the clutch and put it back on before selecting reverse and that usually works.
J
'06' Cooper S Convertible - Astro Black, '04' Mazda RX8 231 - Black
Old Sep 10th, 2005, 10:57 PM   #7 (permalink)
cooper-minx
I live in Mini World!
cooper-minx's Avatar
My brand new Cooper seems to "crunch" when putting it into reverse. I thought it was just the gearbox and clutch wearing in but tomorrow I will try selecting 1st gear before reverse and see what happens.
United Kingdom Female View cooper-minx's Pure Silver & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Sep 11th, 2005, 01:41 PM   #8 (permalink)
cooper-minx
Tried that today and it seems to work. Certainly went in smoother!!
Yet another Gearbox problem??? Ian Clark Faults & Fixes 6 Mar 25th, 2006 03:04 AM
Gearbox problem! debash Faults & Fixes 2 May 4th, 2005 11:00 AM
Gearbox Problem junglemonkey Faults & Fixes 1 Jan 20th, 2005 01:21 AM
Gearbox problem pdubyab Faults & Fixes 19 Sep 29th, 2003 07:19 AM
Gearbox Problem COOPER1.616V Faults & Fixes 9 May 24th, 2003 01:50 AM
