When putting in D/Reverse RPM drops almost to shut
Hello
after turning on the car , when i put in D/R ,the RPM drops immediately for 3 seconds and it almost shuts the car
i think it goes below 0.5 .
what is wrong?
thanks
2002 MINI ONE CVT
Disclaimer: I have never driven or owned a Mini with a CVT transmission. However, from my experience on the forums I have noticed that some people have trouble with them.
Apparently, there is a re-initialization procedure that you can do. I believe this attempts to re-adapt the CVT. Maybe you can try this.
Aside from that, I'd take it in and have it looked at.
Hmm, I've just posted (my first post) in the 1st gen Cooper forum about a similar issue I see with a car we may be buying. Into reverse is fine but into 'D' it stalls. The only way I get it moving is left foot braking and right foot giving it some throttle as I move the lever into Drive.
So no particular help from me but am curious about any possible solutions too.
1) Sudden idle RPM drop on Cooper CVT models during initial 5 minutes of driving when engine is cold, regardless of ambient temperature. (Upcoming fix CD #33?) Car often experiences a near stall/or complete engine stall condition. Current workaround fix is to put key in ignition and turn to "ON" position. Hold the key there for 10 to 20 seconds (Allowing DME to initialize) and then start engine normally. This seems to virtually eliminate the near stall problem when engine is cold. Some regular 5-speed Coopers have also reported this problem.
..and it worked! Still not smooth taking off but no stalling.
Two suggestions from experience:
1. Make sure your car battery is in excellent order.
2. A small blip on the accelerator (only a slight tap, say, to 1,200 rpm) just after starting and before putting into D or R seems to eliminate the engine hesitation.
