My cvts idle changes with air con - MINI Cooper Forum
First Generation CVT & Automatic First Generation MINI Automatics from 2001 - 2006
post #1 of 3 (permalink) Old Feb 20th, 2014, 07:11 PM Thread Starter
Local Time: 02:17 PM
Hi, on idle when you turn the a/c on and off, should the idle speed flog up when you turn it on, and back down when you turn it off, yeh I get that the engine has to work harder to power the air con, still a relatively new mini owner just making sure everything is ok...:biggrin
Josimo41 is offline
post #2 of 3 (permalink) Old Feb 20th, 2014, 07:20 PM
heathwebbo's Avatar
Yes its normal for the idle speed to change when you turn the aircon on as the system does drag a lot of power to run
heathwebbo is offline
post #3 of 3 (permalink) Old Feb 20th, 2014, 07:35 PM Thread Starter
Thank you...
Josimo41 is offline
Fitting air con into r50 Freelanderblue First Generation MINI Cooper 1 Jan 19th, 2014 10:49 PM
Mini Cooper Convertible Air Con Unit Bulbs gone gregbuchanan10 First Generation Interior & Ice 2 Oct 29th, 2013 07:08 PM
air con noise Swardy First Generation Faults & Fixes 8 May 7th, 2013 07:22 PM
Air con stopped working? MCS-W11NJP Second Generation MINI Cooper S 2 Sep 8th, 2012 06:52 PM
Air con issues HHMCS First Generation Interior & Ice 5 Sep 5th, 2012 10:28 PM
