Mini Cooper '05 ( 5 or 6 gears) Transmission Failure Conondrum - MINI Cooper Forum
First Generation CVT & Automatic First Generation MINI Automatics from 2001 - 2006
post #1 of 4 (permalink) Old Jul 12th, 2014, 08:39 AM Thread Starter
Local Time: 08:40 AM
United-Kingdom Mini Cooper '05 ( 5 or 6 gears) Transmission Failure Conondrum
Hello Forum,
I have a Mini Cooper 2005 Automatic; the gearbox starting being funny;
Initially the revs were going too high while changing from 1st to 2nd gear.
I disconnected the battery hoping it was an ECu issue. It worked for a while (rev were now too low when changing).
I noted that when changing from Park to Drive the gearbox had a small lag of about half second to engage with a little bump.
Later on ..the problem begun: The gear would not change from above 1 at all..
A diagnostic unveiled the following messages codes:
1787 gearbox ratio actuator open circuit.
698 gearbox control unit
EGS no communication
ABS no communication
Does this points to the transmission slipping inside and requiring the sheave and chain replacing ?
I am not familiar with error codes, but it does not look like there is a clear indication of mechanical part broken inside the gearbox?
-I am worried I will have to pay for an expensive gearbox dismount when in reality it's an electrical issue only (cables perhaps?)
-On the other hand I am worried that the mechanical repair does not solve the issue and I get dragged in endless repairs involving Ecus.
-Although in good conditions (1 previous owner only, all paper work perfect etc.) my mini is 115 k miles, so thinking whether I should repair it all and find alternative solutions.
-A garage said I am mad and I will waste 2k if I sell the car as it is now since anyone could just repair it and sell it for 4k. However I only have my mini which is essential to go to work and I am not sure whether I have enough skills and time to go all the way to repair it and sell it later on..
Thank you very much anyone could help and advise whether the logs do actually points at mechanical failure / advise what to do next..???
Kate mini is offline
post #2 of 4 (permalink) Old Jul 12th, 2014, 09:26 AM
MINI2 Global Moderator
Sejanus's Avatar
Local Time: 11:40 PM
Quoted: 8 Post(s)
United States Male View Sejanus's Chili Red & White 1st Gen MINI Cooper Profile
Is it a CVT or a true automatic (I can never remember the year they switched to automatics)? When the CVT's suffer a mechanical failure it usually happens pretty suddenly and involves a total failure. Sounds like you have something else going on.
Sejanus is offline
post #3 of 4 (permalink) Old Jul 12th, 2014, 10:59 AM Thread Starter
Thank you for your reply Sejanus,
It is not a CVT transmission, it is a 5 or 6 gear gearbox. I am not sure but it should be "Midlands" transmission...
post #4 of 4 (permalink) Old Jul 12th, 2014, 01:41 PM
BLIKSEM (my brg/brg mc)
cristo's Avatar
Local Time: 02:40 AM
Quoted: 25 Post(s)
United States Male View cristo's British Racing Green & Body Color 1st Gen MINI Cooper Profile
Garage
The 2005 MINI Coopers had either the 5-speed manual Getrag or the CVT (GACVT16Z) automatic transmission.
Before 7/2004, the manual transmission was the Midlands.
If you have a MINI Cooper S, then it's the Aisin (GA6F21WA) 6 speed automatic transmission
(which is much sturdier and more reliable than the CVT in the R50).
cristo is offline
CVT Transmission Failure slaybalj First Generation CVT & Automatic 143 Jun 10th, 2016 03:24 AM
2014 MINI Cooper Hardtop Revealed AutoGuide.com MINI News 15 Apr 23rd, 2015 04:15 PM
New 14 plate Mini Cooper SD Coupe Nightmare Kickboxkel Welcome New Members 7 Apr 4th, 2015 01:33 PM
Mini Cooper '05 Auto Gearbox Failure Conondrum Kate mini Second Generation MINI Tuning 1 Jul 11th, 2014 11:52 PM
