CVT Mini Cooper when cold - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI Automatic and CVT > First Generation CVT & Automatic
First Generation CVT & Automatic First Generation MINI Automatics from 2001 - 2006
Old Oct 23rd, 2003, 07:37 PM
Local Time: 02:34 PM
United-Kingdom CVT Mini Cooper when cold
Hello
This is my first thread, so be gentle with me!
My wife bought a Mini Cooper with CVT, in April 2003, and its brilliant! For 23 years before that she owned an Isigonnis original Mini, which is on its way to the Good Ol' USA.
The only slight quirk, is that when starting from cold, ie when the car has been standing overnight, reverse enages rather sharply and has a tendency to lurch backward. Shifting into drive is fine and smooth. Letting the engine idle for a couple of minutes, before engaging reverse, helps.
Everything else is great!
Has anyone else experienced this?
David
PS: This is a fantistic web site!!!!!!!
Old Oct 23rd, 2003, 08:29 PM
Local Time: 05:34 AM
United States View PigLick's Indi Blue & White 1st Gen MINI Cooper Profile
Do you mean it lurches when you actually put it on gear (ie brake pedal is down, shift from P to R, and get a lurch), or that once you've put it in reverse and step even slightly on the gas, it lurches (ie accelerates very quickly) backwards?
If you mean the second scenario, mine does this a bit too. I've found, hoever, that if you just put it in R and don't give it any gas, it will slowly creep backwards after a few seconds.
I've also noticed that when it's cold, slow-speed driving in general (whether reverse or forward) is very lurchy, ie the gas pedal is very touchy and the transmission kind of struggles with managing rpms and such for a few minutes. However, if I instead slowly creep in reverse out of my parking space (as I mentioned above), once I switch to D and start driving, it's much smoother. My theory is that when you start moving quickly, the CVT fluid is still cold and hasn't had a chance to completely cover all the necessary parts, so things are a bit touchy. Once its had 30 sec or so though, everythings all nice and warm and lubricated, so its all smooth.
PigLick
Old Oct 23rd, 2003, 11:04 PM
punkeyfunky's Avatar
UberGeek
Send a message via AIM to punkeyfunky
Local Time: 01:34 PM
Quote: Originally Posted by David Cable
Hello
David
Yeah, I'm seeing the same thing in my car (a month older than yours). Let the box warm up for a short while first (30-60 secs) and be very gentle on the pedal until you've covered a short distacnce (half a mile will cover it).
Lee
Old Oct 24th, 2003, 08:15 AM
Smile
Its the second senario, where it lurches backward after selecting reverse and accelerating a bit.
I suspected that it may need warming up a bit too, and will try the "warm it up a bit" suggestion.
Thanks for the advice
David
Old Oct 24th, 2003, 05:46 PM
My MINI me and me's Avatar
View My MINI me and me's Chili Red & Black 1st Gen MINI Cooper Diesel Clubman Profile View My MINI me and me's Classified Ads
PigLick
Mine did this and was getting worst making manouvering out of tight spots very trick without practically standing on the accelerator. My dealer reprogrammed an ECU that looks after the Transmission and clutch (yes it has a clutch and not a torque converter). "Mini me" now just has a slight nudge when the D or R is engaged after a cold start and creeps even when cold.
I shall call him..."MINI-Me"! Silver/Black MC 2002-2006 - "MINI Me Too" Chilli Red MCS auto 2006-2008 - MINI Me III Mini Dooper Clubman auto 2008-2012 RIP .......2012 The abominable Skoda Yeti!
Old Oct 24th, 2003, 09:27 PM
rainbowdreamer's Avatar
My CVT lurches a little when cold, but it is within acceptable tolerances. It goes when the engine is warm.
I also notice that (say) when looking for a space in a car park and you are really going slow, the system can't decide what you want to do. At times it can become irritating but I've just got use to it. I do not want any garage tampering around with the settings; so it won't be going back!
Rainbowdreamer
Cooper S Sidewalk
Old Feb 13th, 2004, 05:40 PM
Dirk-Jan's Avatar
Netherlands View Dirk-Jan's Solid Black & Body Color 1st Gen MINI One Profile
I am from the Netherlands and I have the same "thing" with my Mini.
but it also almost stalls when driving when it has been really cold and you stop after a few meters.
Furthermore (It doesnot stop haha) If start the engine and start drive immediately the engine of CVT makes a high peeping noise when I use the throttle. And it doesnot go away. The sound is like an airplaneengine only not so loud. Anyone have the same problem.
Old Feb 13th, 2004, 06:11 PM
MiniDoug's Avatar
MINI2 regular
United Kingdom View MiniDoug's Pure Silver & Body Color 1st Gen MINI One Profile
My car occasionally behaves a bit strangely when cold, but it's usually going forward that's the problem.... I reverse out of my driveway and then drive forward onto a traffic calmed street and have to slow down for the humps! It then becomes a bit lurchy, but settles down a bit when warm. It is still not as smooth as a normal auto when travelling slowly. The revs are also highish at start up and about the first 500 yards ('bout 1500 rpm).
The car was built in July 03. Would the v36 upgrade help this drivability do you think??? I don't know what version I have but I'm deffo not 100% happy with the way the transmission performs.... I'd like more smoothness in traffic; after all I live in London and that's one of the main reasons I bought it... not to have to fiddle around with a clutch when driving in hellish congestion!
Doug
Old Feb 13th, 2004, 06:40 PM
Dirk-Jan's Avatar
Doug
What is the V36 update? A software update for the gearbox?
Old Feb 13th, 2004, 08:36 PM
MiniDoug's Avatar
MINI2 regular
Apparently!
don't know what version I've got!
Old Feb 21st, 2004, 09:33 AM
minifrog's Avatar
Local Time: 11:34 PM
Australia View minifrog's Chili Red & White 1st Gen MINI Cooper Profile
Mine fits the second scenario but a kilometre or two and everything is smooth and silky. No sign of any stalling at any time. It is a great eperience to own a Cooper but the CVT puts the icing on the cake!
Once a 1966 Classic MCS Mark 1 1275cc BRG/white owner. October 2003 build MC owner. :Chilli Red/White
Old Feb 21st, 2004, 11:45 AM
Spookyfish's Avatar
I'm probably out motoring
Netherlands View Spookyfish's Solid Black & White 1st Gen MINI Cooper Profile
No problems here on a (probably) v36 cvt. Picked the car up yesterday. This moring, it was about zero degrees centigrade and it started all fine, driving was smooth. The engine idles around 2000rpm when it's that cold.
Black / Whte Cooper pepper pack; cvt w/paddles; asc+t; white mirrors
Ultrik Cold Air Intake System - Mini Cooper DEye First Generation MINI Tuning 0 Jul 26th, 2005 08:40 PM
Mini One or Cooper CVT? robertc First Generation CVT & Automatic 4 Jul 26th, 2004 04:32 AM
What Mini should have the best long term reliability? Cooper 5-spd, CVT, or Cooper S? johnsocal General Discussion 6 May 12th, 2004 02:36 PM
Mini Cooper CVT? Haris First Generation CVT & Automatic 11 Oct 21st, 2003 09:36 PM
