Stuck Passenger Window - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI Automatic and CVT > First Generation CVT & Automatic
First Generation CVT & Automatic First Generation MINI Automatics from 2001 - 2006
Old Apr 11th, 2004, 08:57 PM
Local Time: 01:34 PM
Talking Stuck Passenger Window
Hi
Can you give me any info about sticking passenger windows?
My car is an 03 CVT and has stuck twice. The passener window,only.
You can press the toggle, hear the click, and nada.
Next day it's fine.
Weird.
I have spent an hour searching through archives, but no new ideas.
Anybody?
Thanks,
jafes
Old Apr 11th, 2004, 09:53 PM
adamlondon's Avatar
England View adamlondon's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
This is a typical BMW design flaw, and I know quite a few people who have suffered this problem. What it boils down to is the fact that the door windows are pillarless, and are therefore not supported. If you open or close the door by pulling or pushing on the glass you gradually damage the winding mechanism. It is almost always on the passenger side as it is not their car and they know no better, whilst the caring Mini/BMW owner would be rather more gentle to their baby! Next time it looks like a friend is going to push the window to close the door, give them a shout! They may think you are nuts, but its better than having the car go back to the dealership every 6 months. It should be a relatively quick fix and covered under warranty. Hope this helps.
All the best,
Adam
Old Nov 1st, 2004, 06:15 AM
Local Time: 09:34 AM
Mini S
Just a heads up -- this happened on my 2003 MINI S as well.
Flip the switch - Hear the click - and see the lights dim -- but no window action.
My MINI is now awaiting service. Bummer too -- I enjoy my windows down with the current weather.
Old Nov 1st, 2004, 09:27 PM
ALD0's Avatar
Local Time: 02:34 PM
I had a Problem with my Windows aswell. Thread is Here
http://www.mini2.com/forum/showthrea...ectric+windows
Old Nov 2nd, 2004, 12:55 AM
Fix your stuck window
interceptor -- thanks for the heads up.
I got a call back from my MINI dealer today. After explaining the stuck window issue -- MINI had a 'fix' for me.
With the car in aux or on -- sit in the passenger seat with the door open.
Press and hold the window switch up
Immediately, while holding the window up toggle -- with your fist -- punch / hit three inches above the large speaker -- three times. <bang bang bang>. Don't be easy on your MINI.
Let go of the toggle switch.
Press and hold the toggle switch up for 5 seconds.
Lower the window completely.
With the door still open
Raise the window completely. The window should have now "re-indexed" itself.
In case the indexing didn't work -- it would be wise for you to lower the window just slightly before closing the door.
Close the window.
Yes -- this worked on my MINI.
Old Jul 19th, 2008, 02:57 PM
Local Time: 08:34 AM
PasqualeIV, thanks, that just worked on my 2002S. I was prepared to spend several hundred dollars to fix it. Now I just have to figure out why my air bag light is on.....
Old Jul 19th, 2008, 09:18 PM
Scotland Male
I just had to bang my door to get the window up.
I think the mechanism need lubed.
Old Aug 4th, 2008, 08:51 PM
DaveR53's Avatar
Caffeine Fuel'd
United Kingdom Male View DaveR53's Dark Silver & Black 1st Gen MINI Cooper S Profile
Thumbs up
Great advice PasqualeIV,
Just saved me a trip to the Service Department
Old Aug 18th, 2008, 09:57 PM
miniredcooper's Avatar
MINI gone - not forgotten
Scotland View miniredcooper's Chili Red & Black 1st Gen MINI Cooper Profile
Guys,
the stalling window saga is caused by a dirt build up/oxidisation on the copper amature of the window motor. The carbon brushes over time leave a sticky deposit which prevents the power getting to the motor.
The thumping of the door trick will work for a few months - and has to be one of the most impressive fixes for any fault but sadly eventually the window will stop altogether.
MINI normally try to charge you for a new motor - but there is an excellent guide on here somewhere on how to strip out the mechanism and clean it so it works perfectly again. Takes a couple of hours to do the job.
I think it is possibly lack of use of the passenger window which causes this as it always seems to be on the passenger door whether Left hand drive or right hand drive.
Old Sep 21st, 2009, 05:34 PM
Thanks!! the dealership wanted to charge me $500 per window to get them fixed! This worked like a charm.
Close the window.
Old Oct 5th, 2010, 09:13 PM
MiniAcadie's Avatar
Crazy Canuck
Local Time: 10:34 AM
Canada Male
Thumbs up
OMG! This worked!
I was thinking about removing the door cladding and working on the window motor with the guidance of my Bentley service manual, but decided to check online before doing anything.
Glad I did
Thanks PasqualeIV
Old Jan 27th, 2012, 01:44 PM
nobbyclark's Avatar
0.1mpg (Miles per Grin)
United Kingdom View nobbyclark's Electric Blue & White 1st Gen MINI Cooper S Profile
I was very doubtful that this would work, but it does! Brilliant.
Driver Window stuck in the up position jwcat First Generation Faults & Fixes 44 Sep 3rd, 2009 03:44 PM
Window stuck nemeton82 First Generation Faults & Fixes 20 May 27th, 2008 10:00 PM
'03 MINI Cooper S Passenger Seat Stuck ice First Generation Interior & Ice 4 Jul 18th, 2006 09:59 PM
Passenger seat too far back/stuck!!! Carcass First Generation Faults & Fixes 3 Jun 21st, 2005 12:44 PM
Passenger Window Bonnie Scotland First Generation MINI Cooper S 2 Sep 15th, 2002 07:28 PM
