engine produces strange knocking G"Morning!!! After installing new cam (schrick) and pulley my engine produces strange knocking (clattering). It sounds like relay engaging/disengaging. The sound is quite strong and noticable in 3 to 6 gears under load from 3000 rpm and up. But if i understand right this is not detonation (going to check the spark-plugs tomorrow). it appears for a second or so then disappear?! and again 500 rpm higher. Not noticable under load at low rpm! Could we made something wrong installing the cam? we did not modify spark-plug tubes though the cam touches it noticable Or could it be bypass valve because of excessive pressure?? Thanx in advance Peter Last edited by Aluminius; Oct 6th, 2005 at 06:42 PM. |
| Strange knocking noise | squeeam | Wheels, Tyres & Brakes | 3 | Oct 19th, 2009 07:24 PM |
| HELP Engine Knocking noise HELP!! | SiNNeD | First Generation MINI Cooper S | 12 | Nov 12th, 2008 04:45 PM |
| what does engine knocking sound like? | mini vanilli | First Generation Faults & Fixes | 10 | Aug 22nd, 2005 12:26 PM |
| Engine Knocking HELP!! | SiNNeD | First Generation Faults & Fixes | 6 | Mar 9th, 2005 03:31 PM |
