Engine revs high after alignment/tire rotation - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 15th, 2005, 06:54 PM
kendertaunt's Avatar
Pixie Posse Racing
Send a message via ICQ to kendertaunt Send a message via AIM to kendertaunt Send a message via Yahoo to kendertaunt
Local Time: 09:37 AM
United States Female
Electic Blue S Engine revs high after alignment/tire rotation
Greeting all,
I did lots of searching here on this... I couldn't find anything. But I'll be honest and say that I don't know my auto vocabulary, so that could be problem in itself. We need a Mini2 Glossary! (ie. what's the different between 'rev' and 'throttle'?)
But I digress.
Here's the problem.
My 2002 MCS (had her for 3 weeks now) drives the same way it does for everyone else... it has the not-so-great torque at a rolling stop in 2nd, etc.
Until...
My car was pulling heavily to the left (in middle lane in highway, I'd let go of the wheel, and it would get right over into left lane by itself).
So, I took it in yesterday. They rotated the tires and gave Eloise an alignment. As soon as I started to drive out of the shop, I thought the engine seemed a little noisier/whinier than usual, but shrugged it off as my obsessive-compulsive imagination.
However, it's been a day and it's STILL just not the same car it was before I took her in. The engine seems so much noisier, and now I'm discovering it's because it's revving much higher than it used to. At a stop, I step on the gas in 1st, and all of a sudden I blink and it's at 4k RPMs. That *never* used to happen. On back roads driving 50mph in 5th, and it's at 3k RPMs. That bad torque in 2nd at a rolling stop? It doesn't shudder at all now, in fact, I got quite a lot of power in 2nd when I was barely moving.
The engine just seems like it's working *really* hard.
IS it my imagination? The only other thing is they did some poking around to find a whistling/wind noise in the front of the car, but I know they didn't change anything. Is it really possible that an alignment/rotation could change the engine that much?
I just thought I'd get some opinions here by other actual MCS owners before becoming "one of THOSE" clients to the dealers.
Cheers,
Kendertaunt
Old Oct 15th, 2005, 07:18 PM
SiBradbury's Avatar
Local Time: 02:37 PM
United Kingdom Male View SiBradbury's Classified Ads
Sounds odd. Check on the sidewall of your tyre and see if the 'ROTATION' arrow is pointing the way your wheels turn when you're moving forward. Some tyres aren't 'rotational' so if you don't find an arrow don't worry. This is the only explanation can think of as your engine doesn't 'know' your tyres have been moved about!!
Old Oct 15th, 2005, 07:39 PM
xtremepsionic's Avatar
Vroom!
Local Time: 06:37 AM
Canada Male View xtremepsionic's Chili Red & White 1st Gen MINI Cooper Profile
Yeah, very odd. I could imagine that if the alignment was off before, your tires would be scrubbing and reducing power, and your engine would sound more "strained". After the alignment the extra resistance should be gone and the engine should have an easier time.
There is no way we can judge if your car is operating correctly over the internet. It is best to check your tire pressure and the rotation of the tires (if they are directional)
By the way, the different revs at 50mph is purely your imagination. Unless they swapped your tires for a different size, your car will not be revving at a different RPM.
Rev = also known as RPM, the rotation per minute of the engine
Throttle = The right side pedal that controls how much air goes into the engine (engine computer controls how much fuel gets injected based on the throttle position and air flow, MINIs have computer controlled throttle plate as well)
Pixie Posse Racing
Many thanks for the quick reply!
I went and checked, no directional arrow. (Dunlop Sport 5000)
Seeing as the Mini is so driver-responsive on a normal day, I will take your advice and wait a bit to see if the tires settle in. In hindsight, I can see how even a minor change could drastically affect the way a responsive car like the Mini would drive...
I'll post back if the situation doesn't change in a week or two.
Cheers,
Kendertaunt
Old Oct 15th, 2005, 07:44 PM
Pixie Posse Racing
After reading that second reply by xtremepsionic (came in after I started replying), I'm wondering if you are correct in that it was the BEFORE situation that was odd, and now it's driving normal.
I know it's hard over the Internet, the only way I could think to describe the problem was by posting how the RPMs had changed.
I went and looked up the tires, that brand is definately not directional. Looks like I need to give it some time to adjust...
Thanks for the reply, it's appreciated!
Old Oct 15th, 2005, 07:45 PM
SiBradbury's Avatar
Another option is to go back and say your car doesn't feel quite right and could they possibly re-check it. Its possible that it has not been aligned correctly, maybe too much 'toe-out'. Putting the tracking guages on a car only takes a matter of minutes, its the actual adjusting that takes a little time. Most good garages will be happy to do this for you if you feel that the car isn't driving how it should.
Old Oct 15th, 2005, 07:47 PM
SiBradbury's Avatar
...or maybe they throw in a free ECU remap with every wheel alignment!!!
Old Oct 15th, 2005, 07:54 PM
Vroom!
If they rotated the tires, it could also be that the wear pattern front vs rear is different, and you will get a different tire noise for a little while.
That could be all the difference
Old Oct 17th, 2005, 01:25 PM
Pixie Posse Racing
Electic Blue S
Just a quick update...
I am going to be bringing the car back to get re-adjusted. It's definately not as big an issue as I thought it was, I just think the alignment/rotation needs some adjusting. I may need a wheel balance also. The real reason I'm bringing it back is because of the steering wheel... it's oscillating on me. It feels very tight now, and pulls itself back and forth, with a preference to the right. In fact, we have a gravel driveway. When I come home and take my hand off the wheel, it goes back and forth, and finally goes WAY over to the right to stop.
I did some research. Remember when I said the engine was so noisy? I have done some more research here, and discovered that the engine noise/whine is, in fact, the supercharger.
It just seems like now after the changes, it's just louder, which is I'm sure the way it was originally suposed to work. D'oh!
I still notice the RPMs are higher from 1st to second, 4000rpm before shifting, and because of this I can practically watch my gas guage go down. But I now believe this is because of the steering wheel oscillating. It's tight.
So, a minor adjustment needed, but I believe thanks to you all and Mini2, I have solved my problem.
I'll post back once it gets completely resolved.
Cheers,
kendertaunt
Old Oct 18th, 2005, 07:50 PM
Pixie Posse Racing
Solved - Engine revs high after alignment/tire rotation
Forget about bringing the car back - I've done even MORE research here thanks to your replies and fixed the problem.
Apparently, having a Mini Coooper means people think, "small car, small tires." My tire pressure was set to 23 PSI on all tires except the front right, which was set to 20 PSI.
Yeah, I found my problem!
I inflated them all to 35 PSI, and it's like I've got a brand new car. No steering wheel oscillation, nice smooth takeoffs, no more engine working harder than it should have to.
Wheeeeeeeeeeeeeeeeeeeeeeeee!
Gotta go motor,
Kender
Last edited by kendertaunt; Oct 18th, 2005 at 07:51 PM. Reason: edited subject line
Old Oct 18th, 2005, 09:47 PM
Vroom!
Yay!
35Psi is great, you'll get better gas mileage too!
Old Oct 18th, 2005, 11:18 PM
Pixie Posse Racing
Seeing as I've only had the car for a few weeks, it didnt' even drive like this when I test drove it, so I think the pressure was low then, too.
There should be a new definition for "Exhiliration", and that is, "driving a MCS."
Every time I changed gears tonight I couldn't wipe the grin off my face. I could *feel* the power of each new gear, and the supercharger.
I can't believe it. I still can't get over it!!
Kender
Old Oct 19th, 2005, 10:22 AM
England View BlackEyedPurple's Black-Eye Purple & White 1st Gen MINI Cooper S Profile
Kender
Welcome to our world
Tire Rotation-when/how? jimmy_racoon Maintenance & MINI Care 35 May 3rd, 2006 11:01 AM
MINIUSA Says about Tire Rotation... OctaneGuy Wheels, Tyres & Brakes 35 Mar 18th, 2005 07:46 AM
tire rotation awayne Wheels, Tyres & Brakes 10 Dec 27th, 2004 04:03 AM
tire rotation.... eddieboyII Wheels, Tyres & Brakes 9 Jun 10th, 2004 06:29 PM
Tire rotation? BigM Maintenance & MINI Care 4 Aug 15th, 2003 10:59 AM
