Very Annoyed - Door Seals! - Had Probs Yourself? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 25th, 2005, 06:50 PM
K9COOP's Avatar
K9LV
Send a message via MSN to K9COOP
Local Time: 02:38 PM
I recently took my 02 cooper back AGAIN
for yet another fault to be fixed
When I bought the car it had streaks up BOTH passenger and driver window and I thought it was polish and it would wash away eventually
I clean the car all the time! And it still appears! Anyways when My driver door got stuck in the UP position and I couldnt close the door properley I thought I would kill 2 birds with one stone and get them to check if there was problem with the streaks!
I got the car 05/05
Mini say my seals on the windows have gone! They told me it was chargeable, ****ed off I agreed to have it done and Im about to take it up with them in writing as I feel the seals on BOTH windows shouldnt need replacing after just 3 years! thats DISGUSTING!
they charged me just shy of £100 for the seals on both sides to be done! NOT IMPRESSED! and The reason I agreed was they said it would cost more if i brought it back later as the technicians had the door apart to fix the problem with the window anyway
Its one of lots of problems
NEW CLUTCH in 03
new seat rails
new strutts (veering to left)
one click needed programming again when it cocked up
Had same prob twice with passenger door not opening
none of my controls working except side lights until turning car off and back on again (still havnt found fault)
seats creaking again
Ive had the car only 5 mths!! Am I missing summat here? is this the faultiest car MAN could buy?
Im very close to putting it into the autotrader and buying an alternative car!
If you have had the probs with smears please let me know, a few friends from a diff mini club say they have and im wondering if its common so when I make a complaint I have a bit of info to back up my annoyance at having to pay!
Thanks in advance
Kelv
Old Oct 29th, 2005, 09:22 AM
mooneymini's Avatar
United Kingdom Female View mooneymini's Classified Ads
Is this a sort of greasy smear on the inside of your windows?
I get that all the time, didnt think of it as much of a problem.....
And after what ive just been through at my dealer (north oxford garage) i dont think i will be sending it in anytime soon.
It is annoying though! I clean my car and as soon as i put my windows down and up again the smears are there.
CENTRE
Old Oct 29th, 2005, 02:03 PM
Tracie's Avatar
I'm Back!
Send a message via AIM to Tracie
Local Time: 01:38 PM
United Kingdom Female View Tracie's Pepper White & Black 2nd Gen MINI Cooper S Profile View Tracie's Classified Ads
The streaks inside the drivers and passenger windows is a common problem..I have it in my Cooper (Feb 04 build), my mum has it in hers (Aug 04 MCS)..mate of mine has it in his 01 Cooper..seems its a common complaint..there is a threa on here somewhere all about it..some ppls have tried silcone spray etc to help the windows slide up smoother....I wouldn't worry to much about it, it doesn't bother me. hth
Old Oct 30th, 2005, 08:20 AM
K9COOP's Avatar
K9LV
Great stuff, Ive had others on other forums saying its a problem, I just wanted something to back me up! Im going to write to them and request my money back as theres no way this should be happening! its a design fault. Will search for the other thread and post it up in here
Old Oct 30th, 2005, 08:26 AM
Rakey's Avatar
Total MINI dot com!!
United Kingdom Male View Rakey's Classified Ads
its easy to fix, just clean the seals and stop grease and muck from building up on them. Its not just a MINI issue, I've had this on many cars I have owned, its just a case of cleaning your car properly and learning to get on with enjoying it instead of being picky
Old Oct 30th, 2005, 08:31 AM
K9COOP's Avatar
K9LV
If its just a case of cleaning it why did BMW replace the seals at a cost of £98?
http://www.mini2.com/forum/showthrea...meared+windows
This thread says it all really... Dont get me wrong Ive had smears on other cars but these were the worst smears ive had on any vehicle so much so I felt the need to complain
The car went it because the window was buggered, I asked them to have a look at the smears at the same time! They advised me the seals needed changing and best to have them done whilst the technician had my door apart otherwise it would cost more next time. Worst car Ive ever bought, looking into buying something else at the moment, Im sick of taking it back with faults (Not my little pickings)
Water leak - door seals trucker First Generation Faults & Fixes 17 Jun 22nd, 2011 09:19 PM
Steering Rack leaks into boot - can seals be replaced? barnhillld First Generation Faults & Fixes 1 Sep 28th, 2005 03:55 PM
Front AXLE Seals Leaking jjondis First Generation Faults & Fixes 0 Aug 28th, 2004 07:18 PM
Window seals squeaking Direwolf First Generation Faults & Fixes 3 Oct 26th, 2002 09:42 PM
Creaking Windows/door Seals. rayasp First Generation Faults & Fixes 2 Aug 22nd, 2002 10:28 AM
