Possible clutch judder in gear and pulling away - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 12th, 2005, 11:13 PM
Peartreeproductions's Avatar
Mini spanker
Local Time: 02:38 PM
United Kingdom View Peartreeproductions's Pure Silver & Black 1st Gen MINI Cooper Profile
Unhappy Possible clutch judder in gear and pulling away
I have a MC with 28,000 miles on it.
From pull away it seems to judder a little more each day, Anything over 1500rpm will always cause the car to judder and it seems that the only chance of it not juddering is to let the car bog down with too little revs. Over the eighteen months that I have had the car it seems to get increasingly worse.
The last few weeks I have noticed that there is some juddder on the move when in second and third gears over 4000rpm and at WOT. Has anyone else noticed this or could it be something other than clutch judder causing it?
Dont get me wrong the whole thing is not severe but definately noticeable. From my single MC experience though it seems that the Mini clutches are not that robust.
Old Nov 12th, 2005, 11:41 PM
SiBradbury's Avatar
United Kingdom Male View SiBradbury's Classified Ads
You could always try putting it in first with the handbrake ON and seeing if it will rev excessively at the 'bite' with a little gas on. If the engine's revving loads with the clutch engaged but the vehicle is still being held by the handbrake, then it must be the clutch slipping. Just an idea.....
Old Nov 14th, 2005, 09:05 PM
Belgium
Hi p3, I have clutch judder as well, esp. when cold and not used for a while. No problem with slip though. Clutch got replaced at 30.000 km and there's 54.000km on the clock now.
The tech at BMW told me - if it ain't broken don't fix it, but I kind of think this should not be happening that soon.
I'm gonna ask them to look into it again, but am wondering if we're just being picky (that is, plenty of mini drivers don't bother about the under-average clutch) or if there is a real problem (i hope) with ours.
Will keep you posted - service is due in 500 km.
flat spot stumble when pulling away in first gear ? (engine cold) Perm First Generation Faults & Fixes 22 Jan 15th, 2007 06:37 PM
Whine from clutch in 1.st gear.. Berger First Generation Faults & Fixes 2 Apr 3rd, 2006 12:53 PM
MC Clutch Judder + throttle response spod First Generation Faults & Fixes 6 Apr 12th, 2005 09:50 AM
Seems to judder when pulling away Mega Mini First Generation Faults & Fixes 20 Jan 3rd, 2004 06:15 PM
clutch/transmission judder, chattering, squid First Generation Faults & Fixes 0 Jul 14th, 2002 09:36 PM
