Gear Change Noise. - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 20th, 2005, 12:58 PM
Judge Cooper S's Avatar
Local Time: 11:12 AM
England Male
Gear Change Noise.
I got a '05 MCS in March which almost immediately developed a fault with the clutch and flywheel. I also noticed that when changing up from 1st to 2nd gear, clutch fully depressed, i could hear the gears going into place under the car (not in a grinding way and not just the noise of the gearstick going into place). As BMW couldn't replace the clutch and flywheel quickly enough I insisted on a replacement.
Having got my replacement '55 MCS I have noticed that when I change up from 1st to 2nd I can occasionally hear the gears shifting into position beneath the car again. Again there is no grinding sound at all and the car drives very smoothly, smoother than my '05 MCS. This occured with the courtesy Mini Cooper I had as well whilst awaiting my new MCS
Is this normal as have been told that mini gearboxes can be quite clunky anyway and as it's a small car u may hear that noise occasionally? Would just like my mind put at rest!
Old Nov 20th, 2005, 06:34 PM
Bilbo Baggins's Avatar
Local Time: 06:12 AM
United States Male View Bilbo Baggins's Space Blue & Silver 1st Gen MINI Cooper S Profile
My '02 MCS and my '06 MCS both make a noise like that. I normally only hear it if my window is open and there is a wall nearby to reflect the sound. Sometimes I will hear the same noise on a 2-3, 3-4, or 4-5 shift By the time I get to a 5-6 shift I'm going so fast the sound gets left behind.
I had 36,700 smiles on my '02 before trading it in with no mechanical woes at all.
'06 MCS SB/S R84s(Kumho Ecsta AST, summer), R81s(Nokian Haakapiilatta 2, winter)
'02 MCS DS/W (retired)
Old Nov 20th, 2005, 09:04 PM
England Male
That's reassuring. Thanx for that. Hope I get same problem free mileage from mine!
Old Nov 20th, 2005, 09:38 PM
England View ZafGsi's Classified Ads
Had my 55 plate S for about 6 weeks now. Noticed that noise straight away. Must admit not that bothered by it. Just assumed it was part of the notchy gearbox i had read about. Anyway, its got three years of waranty so if needs be I'll get a new one if this one turns out to be faulty.
Steve.
Old Nov 21st, 2005, 08:54 PM
England Male
Have found another thread on the same point and it seems the "clonkyness" is just the mini doing it's thing! That's a relief but as u said it's under warranty should anything go wrong.
Noise in first gear MINI Papa First Generation Works 7 May 14th, 2007 03:14 PM
First Gear Noise Nalin First Generation Faults & Fixes 7 Feb 2nd, 2006 12:07 PM
When to change gear?? wee rocket General Discussion 17 Jul 21st, 2005 02:02 PM
Change gear when? C12OGN First Generation MINI One 4 Jan 30th, 2005 09:09 AM
Jerky gear change from 2nd gear stellablade First Generation Faults & Fixes 7 Sep 29th, 2002 11:58 PM
