Auto window down when opening the door... - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 22nd, 2005, 07:34 AM
Local Time: 10:13 AM
Hi all, first post on the site!!! (although been browsing for about 4 months now!! Great Site!)
I got my New Mini Cooper / HB/W about a month ago now (sorry no pics - no digi cam yet!)
As you probably all know the frost has started to set in! and winter is now on us!
The problem started yesterday, when my mrs got out of the passenger side - the window didnt go down a notch - hence the door wouldnt shut. I then put the window down using the leccy, and it worked fine after that, until today!!!! did exactly the same today!! the drivers side opens and shuts as usual - the passenger side doesnt!
Im wondering if any of you had the same problem and to see if its a warranty job or if its just a frozen mechanism?? i find it strange just being the passenger side if its the latter!
Hope someone can help me - i want to avoid taking Hypes back to the garage if i can!!!
Thanks for looking!!!
Old Nov 22nd, 2005, 08:09 AM
Paul's Avatar
MINI2 No.1
England Male
Could be frosty, could be a bad part. Most likely worth a trip to the dealer, assuming you've already tried making sure the window is FULLY closed (press and hold the window switch in the UP position to make sure it's all reset).
Window retraction or my window won't go down when the door is opened minimini36 First Generation Faults & Fixes 15 Nov 27th, 2010 08:07 PM
Drivers Side window not opening... eddycooper First Generation Faults & Fixes 3 Jun 15th, 2007 02:54 AM
Drivers side window opening K2RYL First Generation Faults & Fixes 7 Jun 2nd, 2005 06:24 AM
Random window opening m111n1 First Generation Faults & Fixes 12 Jan 25th, 2004 01:53 PM
Door Opening brycem First Generation Faults & Fixes 3 Dec 22nd, 2002 04:52 AM
