Fan belt noise and oil leak I purchased a Mini Cooper 02 about 5 weeks ago (not from a Mini dealer). It has 31,000 miles. I'm having two problems with it at the moment, I'm hoping someone can help!! The first is a noisy fan belt which I've already had replaced and the second is an oil leak which seems to be coming from the drive shaft. I'm a little concerned as I only have the car a few weeks. Has anyone else had these problems? Thanks. Last edited by JS; Nov 23rd, 2005 at 07:16 AM. |
| Is the fan belt slipping then?? is it a clicking sound?? Where on the drive shaft is it coming from?? out of the giator?? |
| It sounds like it's slipping but it has been replaced. It's not really a clicking sound, more of a squeel. When I looked under the car, It didn't seem to be coming out of the giator. It was coming out of the drive shaft near the center of the car. I didn't see a giator there. Last edited by JS; Nov 23rd, 2005 at 10:48 AM. |
| Thanks for the advice. The noise does get louder when I turn everything on. It seems to be worse when the engine is cold and goes away after a few mins. I left the car in yesterday, hopefully the mechanic will sort it out. |
| Sounds like the belt is slipping on the alternator pulley. I'm sure it will all be sorted Fingers crossed for you.Ooooo better go to work!! |
| Fan Belt | norfi1983 | First Generation Faults & Fixes | 29 | Aug 25th, 2011 09:33 PM |
| Engine fan coming on while driving - coolant leak? | quenching | First Generation Faults & Fixes | 0 | Jul 16th, 2007 08:01 PM |
| How much for a fan belt? | jamski | First Generation Faults & Fixes | 5 | Mar 5th, 2007 06:43 AM |
| auxiliary drive belt / fan belt renewal | sramdeen | Maintenance & MINI Care | 1 | Jan 22nd, 2007 01:23 PM |
| Chirping fan belt | Coopergeezer | First Generation Faults & Fixes | 6 | Dec 15th, 2002 12:01 PM |
