Locking door and open door symbol - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Dec 18th, 2005, 07:57 PM
Local Time: 11:13 AM
England Locking door and open door symbol
Is there an option whereby you can program the car to beep when it is locked? and when the doors are open on mine, the open door sign isnt on anyone know why it could be? it works with my boot but not with the doors is it normal? thanks
Old Dec 18th, 2005, 08:02 PM
dcfkan's Avatar
In exile, down SOUTH!
United Kingdom Female View dcfkan's Chili Red & Lime Green 1st Gen MINI Cooper Profile
I don't think there is such a symbol. The boot has one on the dash as it is not possible to see if it is closed properly when seated, whereas one should be able to tell if the doors are locked by checking if the knobs on the doors are lowered or not.
I could be wrong though
DK :apple:
Old Dec 18th, 2005, 08:03 PM
ta mate ijust presumed it would have one because the boot has i could be wrong
Old Dec 19th, 2005, 12:31 AM
Joker's Avatar
watchalookinat
Local Time: 02:13 AM
Colombia
like a horn beep? never heard of this option b4!!
i havent noticed this yet, ill check fer sure!! it would seem correct to have it only be for the bonnet........
.................................................. ........///g0t PETR0L !? :o(
My boltz require more torque than ur Honda makes.........BUY a VW! .
xx03
Old Dec 19th, 2005, 02:41 AM
CoryB's Avatar
Local Time: 06:13 AM
United States Male
It will only beep if you have the factory (or other) alarm installed. No beep without an alarm though.
Mine only has a light to tell me when the boot or bonnet is open - not the doors.
His - 04 CR/W MCS
Hers - 05 BEP/W MCS
Old Dec 23rd, 2005, 11:36 PM
Joker's Avatar
watchalookinat
Colombia
yep, it does not light up when doors are ajar/open
xx03
Old Dec 28th, 2005, 05:15 PM
England
This is an area that could certainly be improved with the mini. As others have stated, there's only a dash warning light for the boot and bonnet....(trunk and hood of course for the stars n stripes lads). All the doors get is the courtesy light staying on which is noticeable enough when it's dark but of course in the day time, very easy to miss!! Same with the auto lock feature. After a while it more or less becomes transparent to you because the brain treats the repetition as unimportant. So for it not to happen when a door is not shut properly is again, I would of thought very easy to miss!......
central locking on drivers door kazscooper First Generation Faults & Fixes 8 Apr 12th, 2008 09:32 PM
Automatic door locking TallAndy Second Generation MINI Cooper 12 May 3rd, 2007 02:11 AM
Door Locking Sound Confirmation cosmic68 Second Generation MINI Cooper 10 Mar 27th, 2007 01:36 PM
Drive away door locking Helen B Second Generation MINI Cooper S 4 Dec 17th, 2006 11:45 AM
Driveaway door locking wildchild jules General Discussion 6 Mar 31st, 2005 11:50 AM
