| blocked rear washer i took my car into the local dealer today thinking my rear washer pump had gone nope just bolcked, so insted of giving them the pleasure of charging me for it i have decided to have a crack at this myself has anyone had a similar problem and fixed it them selves ??? minitorque.com, the site for mini performance, drag racing track days & time attack its all change for the S, to be revealed soon |
| cheers mate will give it ago tommorw when its light minitorque.com, the site for mini performance, drag racing track days & time attack its all change for the S, to be revealed soon |
| I had a similar problem - just removed the black plastic bit that covers the nut that holds the arm in place, ordered a new one from the dealer for about a fiver, put it on and works.. basically the final bit that diverts water onto the window was blocked. |
| Yeah, same here!! I took it in to BMW to fix one problem and told them to see to the rear wiper spray too as it was spitting poorly - as opposed to the usual jet schoosh. BMW says they replaced the washer and it should work fine now..... However, since then - the problem's come back! This time, no water...not even a spit! I've been trying to book it in so BMW can have another look......just not got round to it!: If I have to pay, then I guess my husband can have a look at it - well the advice has been kindly posted!!! So far, had to drive into all my parking spaces!! |
| Sorted mine with a pin. Normally the nozzle gets blocked. Just stick the pin in the hole wiggle it round. Then run the washer. Might take a few attempts to clear the blockage but will be good as new again. Often caused by dirt that gets sucked into the back of the car clogging the hole. ![]() It was acceptable in the 80's |
i thought that might be it so i pulled it off the car and low and behold a mass of water came jetting out the back cap is now in warm water and holts gald i did that befoure major surgery or even worse letting bmw charge me for the honour minitorque.com, the site for mini performance, drag racing track days & time attack its all change for the S, to be revealed soon |
| My problem only seems to appear when it is below freezing which is most of the time lately here in Maine.... Things work ok when the temps go up. Perhaps this fix may work for me, but am afraid I might crack the cap in the cold trying to get it off. Ideas? |
| Self squirting rear washer | Yoda | First Generation Faults & Fixes | 0 | Aug 11th, 2006 07:54 AM |
| Headlamp Washer Blocked!! | Burgy | First Generation MINI Exterior | 9 | Feb 1st, 2006 11:17 PM |
| Rear Screen Washer | Tbvf | First Generation Faults & Fixes | 6 | Jan 26th, 2005 07:04 AM |
| Rear screen washer... | r34ver | First Generation Faults & Fixes | 5 | Dec 15th, 2004 05:52 PM |
| Do your washer jets get blocked easily? | Mega Mini | First Generation Faults & Fixes | 13 | Sep 26th, 2004 10:19 AM |
