knocking noise when putting foot on acelerator or taking it off.........engine mount - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 17th, 2006, 11:39 AM
Fabio's Avatar
F43i0
Send a message via MSN to Fabio Send a message via Skype™ to Fabio
Local Time: 10:14 AM
Ireland Male View Fabio's Classified Ads
Hi
There's a knocking noise coming from the front of my car when i acelerate or take my foot off the acelerator, its quite loud and very very annoying, its driving me around the bend!
Anybody ever have this problem???
FAbio
update: its a leaking engine mount thats causing the problem
Old Jan 17th, 2006, 11:59 AM
Local Time: 11:14 AM
I had a similar problem, couldnt find what this knocking was, but it turned out to be one of those wood air freseners that where attached to one of the rear grab handles.
Hope you find the problem though.
Old Jan 17th, 2006, 12:03 PM
Yellow and Proud
Send a message via MSN to MartinSSZ Send a message via Skype™ to MartinSSZ
United Kingdom Male View MartinSSZ's Liquid Yellow & Black 1st Gen MINI Cooper S Profile View MartinSSZ's Classified Ads
Mine tends to be the umbrella rolling around in the boot
Old Jan 17th, 2006, 12:46 PM
United Kingdom Male View sv650's Astro Black & Black 1st Gen MINI Cooper Convertible Profile
Ours was the seat belts buckles banging on the trim.
Old Jan 17th, 2006, 02:40 PM
Fabio's Avatar
F43i0
I took all of my junk out of my car to make sure it wasnt causing any rattling,
The car still makes the noise, but it seems its coming from the front now. As soon as i put my the gas on it clunks, and then when i take it off it clunks again. But if i go over a bumpy roads i hear nothing.
I went upto my dealer and asked them could they get a mechanic to take alook and they said "as usual", they dont have a free mechanic, come back on friday and they "might" have a free mechanic . So i just booked it in for next Wednesday. He mentioned that the engine could be loose
Old Jan 17th, 2006, 03:10 PM
Dubman Driver
Send a message via MSN to Karkarinus Send a message via Skype™ to Karkarinus
Local Time: 12:14 PM
Spain Male
may be one of the 2 rear box upper mounts, or just found out today that it could be the downpipe-to-cat flexible part of the exhaust. Apparently it gets excess play and the only way to sort it out is to change it.
Old Jan 19th, 2006, 11:43 PM
Fabio's Avatar
F43i0
I got somebody to drive forward and reverse in the car with the bonnet up and i could see alot of engine movement at the same time i hear the noise, the noise is defintely coming from the engine compartment, may there be a loose engine mount?? or is engine movement normal during accelerating and de-celerating???
Old Jan 20th, 2006, 12:06 AM
cooper_sport's Avatar
A.K.A Gray-Boy
Send a message via MSN to cooper_sport
England Male
Is most likely the engine mount. My car was doing this last month so booked it in for a check. When I picked it up they said they had to replace the engine mount under warranty. The noise has now gone away.
MINI race car driver wannabe
Old Jan 20th, 2006, 11:37 AM
Fabio's Avatar
F43i0
its confirmed, its the right Engine mount, there is a fair amont of leakage there. Also if i rock the engine , it makes that noise on the right hand side strut. The part is ordered, hopefully they'll replace it on wednesday
Old Jan 20th, 2006, 08:27 PM
Best Personal Regards
United States Male View pocketrocketowner's British Racing Green & White 1st Gen MINI Cooper S Profile
What does an engine mount leak???
Old Feb 3rd, 2006, 07:28 PM
I have the exact same problem. I thought I had an oil leak from the engine but it transpires that it is the drivers side engine mount. I do now know what hydraulic fluid is in the mount but it is all over my engine compartment.
Should I be worried?
It is booked in for a warranty repair.
Sting
Old Feb 3rd, 2006, 07:56 PM
Fabio's Avatar
F43i0
Sting
You shouldnt be too worried, just take it easy til you bring it in. I left mine in the garage in the morning and it was ready early afternoon and its going as good as ever now.
How many miles have you done??
Old Feb 5th, 2006, 05:24 AM
Tit's Avatar
Tit
Still kickin' along
Send a message via ICQ to Tit Send a message via MSN to Tit
Local Time: 09:14 PM
Australia Male View Tit's Dark Silver & Black 1st Gen MINI Cooper S Profile
I have been having this problem and have been going crazy listening to it! I have finally noticed (duh!! I must be BLIND!) a whole lot of fluid burnt to parts of the engine bay - so I took some photos -
See Pics here
My knocking noise is exactly the same as you described. If anyone is troubleshooting their car, and wants to compare symptoms, mine are:
- knocking noise, when in gear, upon accellerating or taking pressure off accellerator.
- does not always happen, but happens often
- happens in all gears, usually when releasing the clutch into the new gear.
- It is more prone to happen in lower gears
- sometime does it on start-up
- does not do it in neutral
- engine shakes a bit more than normal on start-up
I have not confirmed that it is in-fact, the engine mount, but oil would not burn on hard to the metal like that, and there are no other sources of fluid in that area of the car. The car is going in tomorrow afternoon to be fixed.
Old Feb 5th, 2006, 11:01 AM
Fabio's Avatar
F43i0
See Pics here
the pics are the same as mine, once they replace the engine mounts everything will be back to normal
  #15 (permalink)
Old Feb 7th, 2006, 08:10 AM
Tit's Avatar
Tit
Still kickin' along
Yup...got the car back today - it's being replaced under warranty....now I have to wait for the parts to arrive from Germany....
boooo...klik klik klik for another two weeks...
HELP Engine Knocking noise HELP!! SiNNeD First Generation MINI Cooper S 12 Nov 12th, 2008 04:45 PM
knocking noise Kim Northcote First Generation MINI Convertible 0 Jul 3rd, 2007 09:17 AM
Knocking noise from engine on MCS DurhamFox First Generation Faults & Fixes 1 Nov 16th, 2005 08:39 PM
Knocking noise in the engine scottkate First Generation Faults & Fixes 6 May 13th, 2005 04:41 PM
knocking noise scenicsully First Generation MINI Cooper S 2 Apr 10th, 2004 12:03 PM
