| No indicators, won't lock, brake lights on...etc! Hi all, I know this is not strictly *stock Mini* related but it was enough of a shock happening to me this weekend that I hope this post might help out others... Background: I have a stock Mini One 2006 with Sat Nav, Boost cd and a whole load of other options. I also have a Dension IceLink running latest firmware and an iPod Nano 4GB. Everything has been fine for the last 6 months. I updated my Nano software to 1.1 on Fri night. Went to the car on Sunday, plugged in teh Nano and the following happened... - no music from Nano, in fact only CD and FM could be selected CDC had dissapeared. - indicator led in dash no longer worked. - brake lights were on contantly (even with engine off) - ice warning was bonging away - window dropped when I opened the door but wouldn't go back up I pulled the battery, waited 5 mins and plugged it back in....now, on top of what is listed above I got: - doors would not unlock or lock with key fob - car took twice to start - stereo said 'DISABLED' At this point I was a little worried but remembered in the back of my mind similar problems listed with the early IceLink modules. Mine is the newest revision but I figured it would be worth a try. I pulled the battery, took out the stereo and disconnected the IceLink piggyback cable. Reconnected everything and THANK GOD it all worked again. I mailed Mike at NewMiniStuff and he agreed it was likely to be the culprit - he is swapping out the IceLink module as we speak (THANKS MIKE!!). So - hope this helps some of the other of you - I would be interested to know if anyone else had problems after upgrading to Nano 1.1 software or is it just coincidence??? Cheers - Rich Mini One with *lots* of toys... http://rakh1.blogspot.com http://homepage.ntlworld.com/richand...mini/index.htm MINI2.COM Stickered up |
| Nano 1.1 upgrade killed my Mini (I think)??? Hi all, For the long post of what happened go here : http://www.mini2.com/forum/showthrea...66#post2205466 . All I can say is it was weird and thank god I purchased from Mike at NewMiniStuff and he has seen similar problems before. I am interested to see if anyone else has upgraded their Nano 4GB to the new 1.1 software version and if it has given them problems with their IceLink+??? Cheers - Rich Mini One with *lots* of toys... http://rakh1.blogspot.com http://homepage.ntlworld.com/richand...mini/index.htm MINI2.COM Stickered up |
| Clear Rear Brake lights / Indicators | JCW225 | First Generation MINI Exterior | 5 | Jun 27th, 2006 04:37 PM |
| Standard rear lights with clear indicators | minicore | First Generation MINI Exterior | 11 | Jun 21st, 2006 01:28 AM |
| Changing the front Indicators/Side lights | DonkeyD | Maintenance & MINI Care | 2 | Feb 8th, 2005 07:39 AM |
| Front Brake Lock up | fourbrews | First Generation Faults & Fixes | 0 | Mar 30th, 2004 07:42 PM |
