Burning smell from engine - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 24th, 2006, 08:22 PM
MINIME
Local Time: 11:14 AM
I have a burning smell coming from the engine of my 10 month old MINI one. The manager of my dealer is trying to assure me that this is completely normal, anyone else have this trouble?
It's not strong at the moment but noticable when the bonnet is up and the engine is running, the first time that i noticed it I was on ramp going up to a multistorey car park and it absolutely stank all around the car park (not normal I would say, but they argued otherwise).
The burning smell is slightly rubbery, the manager told me that it is just heat that I can smell and the rubber is because the covers over the pipes and stuff in the engine are made of rubber. He said that the smell in the multistorey could have been my clutch and that any other car would have done the same, as I was stopping and starting a lot in a queue.
What do you think am I being fobbed off. It was taken in for this problem yesterday and they test drove it and told me that there was no problem, I took it back today and lifted the bonnet and then they told me that it was just heat. They have taken it in to the garage tonight, just to check it but are adamant that there won't be a problem.
HELP and ADVICE required please
Carla_Pink
Old Jan 24th, 2006, 08:31 PM
baskers's Avatar
Local Time: 10:14 AM
Well, it's with them, so hopefully they'll diagnose a problem if any. It could be that you like to burn the clutch , or alternatively there may be a problem - as a burning engine is not a normal smell! Fingers crossed and keep us updated!!
Jay
Old Jan 24th, 2006, 08:34 PM
MINIME
I don't burn the clutch I promise. I've took it back 3 times before this because the clutch has always been clunky and is very prone to grinding even when your foot is to the floor, they said that this was a characteristic of the car.
Carla_Pink
Old Jan 25th, 2006, 06:48 AM
Tracie's Avatar
I'm Back!
Send a message via AIM to Tracie
United Kingdom Female View Tracie's Pepper White & Black 2nd Gen MINI Cooper S Profile View Tracie's Classified Ads
I had a very very strong smell of Coolant coming from mine a few months back and that was because the coolant level was below the min level and there was also an air block in the coolant system ( all sorted now and no smells)...
Old Jan 25th, 2006, 07:05 AM
Root Ginger's Avatar
Amiga 500 to PS3 20 Years
Sounds like the clutch may not be adjusted properly and so even with the clutch down it is very slightly engaged. You would probably find the biting point very low if this was the case though. How far up do you need to move the clutch pedal before the clutch engages?
It was acceptable in the 80's
Old Jan 25th, 2006, 10:49 PM
Isn't the clutch hydraulic - therefore not adjustable ???
Burning smell is not normal - end of converstaion. Get them to take you out in another Mini, bet it doesn't do it !!!
Martin
Old Jan 26th, 2006, 07:02 AM
AFAIK there is a screw adjustment after the hydraulic system. I'm sure I read about someone else on here having to get it re-adjusted. It was a long time ago though.
burning smell from clutch adamos o3,cooper s First Generation MINI Cooper S 4 Oct 19th, 2006 11:44 AM
burning smell Alfie First Generation MINI One 1 Aug 26th, 2006 11:27 AM
burning smell when accelerate MINI T First Generation Faults & Fixes 9 Aug 8th, 2006 09:57 PM
burning smell is it me? Critical First Generation MINI Cooper S 14 Dec 28th, 2003 06:44 AM
Burning Smell from Exhaust Rouskous First Generation Faults & Fixes 9 Jun 10th, 2002 05:23 PM
