ASC+T Warning Light - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 1st, 2006, 06:06 PM
Gemini4321's Avatar
Send a message via MSN to Gemini4321
Local Time: 10:14 AM
United Kingdom Female View Gemini4321's Classified Ads
ASC+T Warning Light
Can anyone help, twice now I have had the ASC+T warning light flash on then go out, I wasn't driving fast or braking hard.
Should I get the dealer to check this out ???
Gemini
Old Feb 1st, 2006, 06:18 PM
Paul's Avatar
MINI2 No.1
England Male
Where you changing gear, pulling away from a standstill, or accelerating at the time?
Old Feb 1st, 2006, 06:23 PM
Gemini4321's Avatar
Hi Paul,
I was pulling away from a standstill this time, cant remember when it happened last time.
Gemini
Old Feb 1st, 2006, 06:33 PM
Paul's Avatar
MINI2 No.1
England Male
Sounds normal to me then, you don't have to feel it working for it to be working.
Old Feb 1st, 2006, 06:41 PM
Gemini4321's Avatar
Thanks Paul
No need to worry then.
Gemini
Old Feb 1st, 2006, 06:47 PM
Paul's Avatar
MINI2 No.1
England Male
No, sounds perfectly OK to me.
Old Feb 1st, 2006, 07:23 PM
HarryHBMCC's Avatar
Local Time: 05:14 AM
Canada Male View HarryHBMCC's Laser Blue & Black 2nd Gen MINI Cooper S Convertible Profile
ASC+T first tries to slow the wheelspin using the brakes. You may even hear them clicking but you won't feel it like when ASC+T goes to the next, more drastic level of retarding the engine. You'll feel that for sure!
On some BMWs the light doesn't flash when just the brakes are activated but on the MINI it is activated for both stages.
Harry
Old Feb 1st, 2006, 07:46 PM
Root Ginger's Avatar
Amiga 500 to PS3 20 Years
Local Time: 11:14 AM
Not true. My 2003 Cooper S only lights up when it retards the ignition not when applying the brakes. However my 2001 reg Cooper lights up for both. Was very confusing when I got my S as I thought there was something wrong.
It was acceptable in the 80's
Old Feb 1st, 2006, 07:50 PM
HarryHBMCC's Avatar
Is the difference ASC+T on the Cooper vs. DSC on the S?
Harry
Old Feb 1st, 2006, 07:55 PM
No, I only have ASC+T on my S too
Old Feb 1st, 2006, 08:32 PM
Gemini4321's Avatar
Thanks all for the replies
Gemini
Old Feb 8th, 2006, 05:58 AM
xtremepsionic's Avatar
Vroom!
Local Time: 03:14 AM
Canada Male View xtremepsionic's Chili Red & White 1st Gen MINI Cooper Profile
Harry
Thats not it. ASC will first reduce engine power, and only at lower speeds with excessive wheel spin on 1 wheel (since most Cooper and Cooper S have open differential, when excessive power is going to the wheels on snow/ice, 1 wheel will spin while the other doesn't) that ASC will engage braking on that spinning wheel so engine power is transferred to the other non spinning wheel.
Old Feb 8th, 2006, 04:03 PM
That's exactly right. It doesn't mean that it can't apply both brakes though. This is what it ends up doing.
In a straight line it applies the brakes on the side that is first to spin, this transfers power to the other wheel this starts spinning so it brakes on that wheel and starts to ease off on the other. This all happens so fast though that it is just essentially applying the brakes to both wheels. Then once the system realises that this isn't curtailing the spin it cuts throttle.
Old Feb 9th, 2006, 03:33 AM
hyprblu's Avatar
Local Time: 09:14 PM
Australia Male
My warning light is on all the time.....I usually switch it off except for wet days.......the system has nearly killed me a couple of times by cutting the engine when I am pulling out into traffic...especially to the left....so now I switch it off and learned much more about controlling the power to the wheels myself.
ASC and Engine Warning Lamps ON Cooper Man First Generation Faults & Fixes 13 Oct 5th, 2010 10:22 AM
ASC+T warning light problem? wilywhitewombat First Generation Faults & Fixes 3 Jul 9th, 2007 10:40 AM
asc warning light coming on george p First Generation MINI Tuning 21 Jan 4th, 2007 08:37 AM
Faulty ASC Light claudeG First Generation Faults & Fixes 2 Oct 23rd, 2006 01:50 PM
Chrome Line Interior for Hazard Warning Light and Display Light Buttons matt1584 First Generation Interior & Ice 1 Mar 18th, 2005 08:18 PM
