Tailgate hinges shifting... - MINI Cooper Forum - MINI2 Mini Cooper Forums
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old Feb 4th, 2006, 01:47 PM
Local Time: 05:14 AM
Hey all, this is my first post...probably first of many. We got a used 2002 mini cooper for my wife. We have had a bunch of stupid little problems with the car since getting it and the latest one is bugging me...
The tailgate when closed is not aligned properly...it sits too low, almost scratching the bumper. When I open it, I notice the two hinges at the top look like they are pulled away from the car about 1/4" - 1/2" Wondering if I can use a block of wood and mallet to just tap them back in, or if they are actually threaded bolts that require disassembly.
Anyone else seen this problem? Does anyone have the service manual pages for removing/installing the rear tailgate from the body of the car? Any advice will be much appreciated...
Thanks!
-mark
Old Feb 4th, 2006, 06:12 PM
Root Ginger's Avatar
Amiga 500 to PS3 20 Years
Local Time: 11:14 AM
Hmm not sure there's any adjustment in the rear tailgate.
Pictures would probably help us diagnose the problem and solution
It was acceptable in the 80's
Old Feb 4th, 2006, 06:23 PM
DaFlake's Avatar
MMC Member
Local Time: 06:14 AM
Welcome to the forum... Photos would help. Are you sure that this vehicle has not been in any accidents, that sounds awefully like it was rear ended.
Old Feb 4th, 2006, 07:04 PM
I agree Super Flake, or it could have been bent through overloading and slamming the boot shut. I wanted to see pictures of hinges, tailgate shut to show panel gaps and close up of nearly rubbing against bumper.
Should be enough for us to hazard a guess
Old Feb 6th, 2006, 03:57 AM
damiond's Avatar
Pirate Monkey Boy
Local Time: 08:14 PM
Australia Male View damiond's British Racing Green & White 1st Gen MINI Cooper Profile
Are you sure the hinges are out, and not the little rubber stoppers?
I seem to recall reading some instructions somewhere about a delicate way to adjust the rubber stoppers for when the boot doesn't quite close correctly.
Old Feb 6th, 2006, 01:41 PM
Will post some pics of the hinges and the door position when shut. Like you guys said, it *could* have been in an accident at some point. The title was clean, but we know that doesn't necessarily tell the whole story
-mark
Old Feb 6th, 2006, 10:09 PM
Local Time: 10:14 AM
Make sure the rubber bump stops are adjusted outwards until you measure 38mm from the tailgate/body to the end of the bump stop.
You can also adjust the tailgate via the two bolts that hold the catch in place which are easily accessible if you remove the blanking covers and then adjust the 10mm bolts outwards slightly making the tailgate sit more proud if you understand what i mean?
Old Feb 7th, 2006, 01:11 PM
Ok, pics are attached. As you can see its the vertical alignment that's off. The right hinge has some marks which make me think it has been repaired already...
Let me know what you guys think. (and please excuse the sticker and dirt...this is my wife's car
If anyone has service manual pages regarding adjustments to the tailgate, they would be helpful...closest mini dealer is 1 hour away, so I am hoping to just adjust it myself.
-mark
ID:	109567   Click image for larger version
ID:	109568   Click image for larger version
ID:	109569   Click image for larger version
ID:	109570   Click image for larger version
Old Feb 7th, 2006, 01:24 PM
OK, that is a lot worse than I imagined. Those tailgate hinges should be flush with the bodywork. You can see the lines where they used to rest. Almost looks like they are very loose or bent.
I will post pics of my hinges for you to compare in a bit.
Old Feb 7th, 2006, 03:50 PM
OK, I would say for certain that the hinges are either bent or need tightening. Took various pics of my two MINIs. You should see from the pics where it should sit flush.
Click to enlarge images
Old Feb 7th, 2006, 04:02 PM
Just taking another look at those pictures reveals that they either are not adjustable or would need to be done from the inside as there is no nut on the outside.
Two ticks I'll go and get my Haynes manual out...
Old Feb 7th, 2006, 04:10 PM
Unfortunately it mentions nothing about the tailgate hinges. Only how to remove the tailgate itself from the hinge. It is possible then that it could be riveted on. This could mean drilling out the rivet and refitting with a new one.
I'll let some other people give their views though now we have pictures of damaged and regular hinges.
Old Feb 7th, 2006, 04:11 PM
DaFlake's Avatar
MMC Member
I believe that they are rivits... I seriously think that his MINI was rear ended.
Old Feb 7th, 2006, 04:20 PM
... yeah, and then fitted a new bumper and tailgate. I reckon the rivets are loose and had been hammered back into place and worked there way loose again.
I take it the tailgate wasn't misaligned like this when you got it. TBH if it has a new bootlid then worse case (provided everything is straight) it will need new hinges and re-riveting. Not too much hassle really.
  #15 (permalink)
Old Feb 7th, 2006, 06:29 PM
Thanks, all for the pics and insight. The door sagged just a little when we bought it, but I didn't think much of it. I didn't notice the hinges being separated from the body until last week. It IS possible that it was rear ended before we bought it. I would have no way of knowing at this point.
I suspect that the hinges must be accessable from the inside of the car though. Since the rivet has no hole for a pin, I don't think it could be inserted from the outside. Either riveted from the INSIDE or there may be a nut somewhere inside. So Haynes doesn't mention anything of it?
It is Haynes that does the "official" service manual or Bentley, or someone else?
Anyone else have any service manual detail?
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-faults-fixes/109326-tailgate-hinges-shifting.html
Posted By For Type Date
MINI COOPER :: North American Motoring - Boot Hinge Broke This thread Refback Jan 2nd, 2009 10:49 PM
Chrome Hinges not Showing as Option in OL Genevieve General Discussion 1 May 10th, 2005 03:57 PM
Paint missing near hinges meanboy First Generation Faults & Fixes 11 Aug 22nd, 2004 11:44 PM
Chrome Boot hinges mra First Generation MINI Convertible 4 Aug 13th, 2004 10:16 PM
Chrome boot hinges Kinster First Generation MINI Convertible 1 Jun 26th, 2004 06:57 PM
Exterior Door Hinges? minikid First Generation MINI Exterior 41 May 22nd, 2002 04:18 AM
