bloody run flats - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 4th, 2006, 02:29 PM
Local Time: 11:27 AM
England
Unhappy bloody run flats
i have 52 reg mini one
had new tyer fitted and since then runflat indicated and abs light keeps coming on had tyre replaced and its still there
had it checked no body nos what it is
car is out of warranty so dont want to take it back to dealer because they ll hammer me does any body have any clues???
Old Mar 4th, 2006, 04:29 PM
Tonyt3's Avatar
Track addict
Local Time: 12:27 PM
still worth taking to the dealer as it may be a symptom of a larger problem. Yes, they are expensive but what if you have a major saftey issue and are driving around in a defective car...?
If the tyre pressures are holding constant in the new tyre then the issue lies elsewhere, perhaps with the ABS system itself...
Old Mar 4th, 2006, 04:54 PM
laura f's Avatar
off out....
Send a message via MSN to laura f
United Kingdom Female View laura f's Classified Ads
I had a dodgy sensor on our 51 reg mini one a couple of years ago, could be that?
Old Mar 4th, 2006, 05:15 PM
England
cheers
any clues on how much this may cost
Old Mar 4th, 2006, 05:52 PM
zimbo's Avatar
Scotland Male
I used to have an 02 cooper, if lights still on then when you have ignition on or engine is running and light is on then press the little tyre button which is located between the front seats if I remember correctly. Hold the button in for a little while till the light goes out and then that should be it ok.
as for the ABS light, well im not gonna be much help with that sorry.
Old Mar 4th, 2006, 07:54 PM
MINIAC's Avatar
Canned
Local Time: 04:27 AM
had new tyer fitted and since then runflat indicated and abs light keeps coming on.
I had problems on my May 2002 build MCS with the Tire Pressure and DSC lights coming on for no apparent reason. Resetting the Tire Pressure Monitor System cleared the lights but only temporarily. The dealer finally had to replace the Steering Angle Sensor.
Old Mar 4th, 2006, 09:40 PM
Widgey's Avatar
United Kingdom Male View Widgey's Chili Red & Body Color 1st Gen MINI One Profile
I'm sure there was a recent (last 6 months?) recall (although BMW never call stuff like this a recall...that has negative implications ) for early models to re-route the wiring for the ABS. The symptoms you are experiencing might be related. This is NOT chargeable by a dealer (whether you are in warranty or not) so take it in and get it checked . It is usual for a dealer to check if their are any outstanding recalls every time you go for a service. I got a letter about something like this but I still haven't got around to getting it sorted yet
Old Mar 6th, 2006, 12:35 PM
United Kingdom Male View S1.6 BJD's Classified Ads
If you have had a flat or adjusted tyre pressures significantly, you should recalibrate the sensor by
pressing and holding the reset button bythe handbrake. If the light was flashing before it should then go out. If it is on permanently and not flashing, and possibly also the DSC light is also on, then the steering angle sensor may be faulty , as mine was, which was a common recall so should be covered under warranty or if out of warranty, it's; done on 'goodwill' at no cost to you. So I would approach the dealer for an opinion at least.
Old Mar 7th, 2006, 06:28 PM
England
thanks everyone least now i have a name for it
Can I swap from run flat to non run flats on a cooper s teaserftm Wheels, Tyres & Brakes 6 Oct 31st, 2007 09:29 AM
Mixing Run Flats with non Run Flats Aberdeen Al Wheels, Tyres & Brakes 3 Feb 2nd, 2007 03:38 PM
Run flats versus non-run flats tceditor Wheels, Tyres & Brakes 10 Apr 26th, 2006 09:49 AM
Run Flats are Gone...!!! amalgam786 Wheels, Tyres & Brakes 21 May 17th, 2005 09:12 PM
Replacing run flats with non run flats? minifrog Wheels, Tyres & Brakes 2 Oct 24th, 2003 04:14 AM
