DSC and Service Engine Soon lights are o - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 12th, 2006, 09:57 AM
norm03s's Avatar
Local Time: 06:17 AM
United States View norm03s's Dark Silver & Black 1st Gen MINI Cooper S Profile
Toggle switch for DSC not responding, DSC stays off with warning light on.
Stumbling at idle, stalled a couple of times, runs at speed and accelerates fine.
I had to heel and toe it to keep it running in stop and go traffic.
This just started this morning, has anyone experienced these same symptoms?
What was the fix?
"I have no data yet. It is a capital mistake to theorize before one has data. Insensibly one begins to twist facts to suit theories instead of theories to suit facts."
- Sir Arthur Conan Doyle
Old Mar 12th, 2006, 12:35 PM
bubblegoose's Avatar
MINI2 Sponsor
Send a message via MSN to bubblegoose Send a message via Yahoo to bubblegoose
Local Time: 10:17 AM
Aruba Male
What was the fix?
a friend of mine had that problem. Not too sure if it will be the same fault but they had a boost pressure sensor that failed... new one fitted - Fault solved!
Call the MINI Assistance if its still within warranty & it'll get sorted
Hope its running better soon
MINI2's Loveable Goose
Old Mar 12th, 2006, 02:36 PM
norm03s's Avatar
bubblegoose, If your friend is on this forum please have he/she post their experience and symptoms.
Old Mar 12th, 2006, 03:36 PM
Windy Miller's Avatar
Feelin the force
Send a message via MSN to Windy Miller
England Male View Windy Miller's Pure Silver & Black 1st Gen MINI Cooper S Profile
bubblegoose, If you friend is on this forum please have he/she post their experience and symptoms.
Hello mate, that friend would be me
symptoms were pretty much what you have described above.
Car wanting to stall at idle, warning lights but also the car did not like to be held at constant revs, it would start to miss and stutter.
diagnosed as the boost sensor, this was changed now all is fine.
hope this is of some help
Ste
Old Mar 12th, 2006, 04:21 PM
norm03s's Avatar
Windy Miller, thanks for that confirmation. I guess I'll leave it to the Dealership to fix, still have Warranty.
I just like to do my own research on the forums, we have a quite a bit more depth of experience here than any one Dealership Tech.
Old Mar 12th, 2006, 08:34 PM
norm03s's Avatar
Thanks to Advance Auto Parts I have a code
Vehicle Scanned
Global OBD11
Vehicle
DTC (CODES)
P0108
MAP/BARD
Circuit High Input
Their scanner would let me clear the Service Engine Soon light but would not clear the DSC disabled lamp. Toggle switch still won't toggle DSC on/off.
Engine still trying to stall at idle, I can see that it is running real rich by looking at the exhaust tips, almost wet with fuel at idle.
Old Mar 14th, 2006, 10:06 AM
norm03s's Avatar
Update and thanks for your input
I contacted a fellow that had the exact same problem and it took awhile to figure out.
In his words;
"Map sensors - all of them!"
"Dealer replaced them (twice) and reset the ecu.
car just lost its mind.
Would not communicate with the throttle body."
"It took a BMW field engineer to do a diagnostic the second time around after the mechanics failed by just replacing one sensor at a time and testing to (me) see if that fixed it."
"They had a BMW field engineer put it on their gt1 diagnosis machine.
They replaced all the sensors t-map, map, steering wheel angle and reset the ecu.
I put the MINI in the shop this morning, still in warranty but not out of the woods yet.
I am going to share with them what was discovered with the other MINI with these exact same symptoms.
I think we have on the forum a great potential for a knowledge base with our combined trouble experiences to create such a knowledge base. The only problem here is a naming convention for indexing and easy retrieval. The search function suffers because symptoms aren't categorized as problems are reported.
Oh yeah, they gave me an 06 MCSC 6 speed as a loaner, it was sunny and 74 degrees here today..........top down…..sweet
PS They called and said still diagnosing problem.
Old Mar 16th, 2006, 02:49 AM
norm03s's Avatar
MINI fixed:thumbsup:
Tech replaced both MAP sensors. He said that during diagnostics the CAN (Controller Area Network) BUS would not communicate with the ABS. There weren't any visuals or other indications form the ABS that it was in trouble that I could tell. Now I'm not sure what the relationship is with the ABS disabling the DSC but that was the case.
As soon as the MAP sensors were replaced trouble cleared. He did not have to reset the ECU. He also took it out for a thorough test drive, used about 1/2 a tank of fuel. I mentioned that and that I was glad he did the testing. He then replaced the fuel from their supply.
This just happened to be MINI Night out #4 hosted by the dealership. All the Techs were there giving Technical demonstrations in the shop area so I got to meet him and debrief about the problem. :thumbsup:
MINI is running strong
For more on CAN BUS;
http://www.interfacebus.com/Design_Connector_CAN.html
Old Mar 16th, 2006, 05:46 PM
Feelin the force
Glad to hear you got it sorted
Strange CEL & DSC lights on... DarkMiniCooperS First Generation Faults & Fixes 3 May 12th, 2011 08:34 PM
dsc light comes on with service engine light mootheking First Generation Faults & Fixes 4 Feb 21st, 2007 06:29 PM
DSC comes on after hard brake, Service Engine Soon light on now roymo First Generation Faults & Fixes 5 Nov 29th, 2005 08:43 PM
SES, DSC, EML lights come on tonjohn First Generation Faults & Fixes 3 Mar 8th, 2005 08:12 PM
DSC and flat tyre warning lights Koala First Generation Faults & Fixes 1 Aug 3rd, 2002 07:55 PM
