| Hi, There could be a number of reasons for your headlight problem. 1) The controller for your headlight - depends when your car was built early cars had a seperate Light ECU, later cars sept 03 onwards the controller was moved into the Body Computer. One of the outputs could be faulty. Im not sure how you can check this because it is a stepper motor output. (Haynes manual info!!!!) 2) The headlight motor is jammed. When you switch the lights on i think it does a reference run to zero (fully aiming down) then adjusts to the correct set position. It would be worth getting someone to switch your lights on and feel the headlight or listen to to determine if it is trying to operate |
| Mini electics can be a bit of a strange phenomena. When there has been a heavy rainfall, I switch off my headlights and sometimes my boot unlocks. Never happens when I try to demonstrate the fault at the dealership. funny eh! |
| Electrical/running issues (not the usual I think) | relive | First Generation Faults & Fixes | 6 | Jan 27th, 2010 08:20 AM |
| Electrical Failure | Kurtster | First Generation Faults & Fixes | 0 | May 9th, 2005 03:56 PM |
| Electrical windows on the One | mreime | First Generation MINI One | 4 | Jan 27th, 2004 08:24 PM |
| Electrical problems | JackBauer | First Generation Faults & Fixes | 2 | Oct 21st, 2003 05:59 PM |
| Electrical Issues???? | cgh1120 | First Generation Faults & Fixes | 2 | Nov 12th, 2002 02:34 PM |
