| I remember when I first test drove my first MINI I asked the guy at the Chevy dealership what the whiny noise was that I only noticed at very slow speeds, like parking. They of course didnt know being a Chevy dealer and had their mechanic take a look at it. It of course turned out to be the electric power steering, a noise that you dont hear in other cars because the power steering is not usually run by electricity. Just a thought. Turn on the car and turn the steering wheel and see if that is the whining you hear. |
| it happens when i turn it on, but before i ever put it in gear. and it happens after i turn it off. it really sounds like an antenna going up and down. but my antenna doesn't go up and down. i hadn't even noticed it til my passenger asked if it was the antenna a couple weeks ago. and of course, now i've been trying to figure out what it is. when turning it off, i thought maybe that was the locks going up ... but that wouldn't explain the same sound when turning the car on (after i've gotten in, so at least the driver's lock is up). hence, i'm stumped! and curious! |
| It's the fuel pump priming on startup but I've never understood the whirr after you switch off which comes from under the bonnet and not the fuel pump in the rear. If you lift your bonnet, lower the window and then switch the car off by leaning through the window, you can get round to the front to hear the noise in all it's glory ![]() It was acceptable in the 80's |
| whining sound | Rishy | First Generation MINI Cooper S | 15 | Oct 19th, 2007 01:15 PM |
| Hyperactive turn signal / turn indicator behavior | CooperCooper | First Generation Faults & Fixes | 3 | Mar 14th, 2005 10:15 PM |
| Whining Sound | titchener | First Generation Faults & Fixes | 6 | May 2nd, 2004 06:20 PM |
| Whining Sound | david_75 | General Discussion | 7 | Oct 4th, 2003 07:55 AM |
