| Depends on where it is. Cooper - under the bonnet. Lift the weater strip that runs across the battery cover and unclip / lift off the battery cover (passenger side big black box). Use a spanner to loosen the -ve terminal and lift off. Cooper S - it's in the boot under the carpet. Never seen one, so I'm assuming it's similar. Always safer to take off the -ve in case your spanner hits any bodywork. ![]() R56 MINI Cooper S JCW Challenge |
| I can't believe this worked!!!! Thanks all. Y'all saved me $1000 AUD. Got a missed call on my cell phone this afternoon from BMW...my guess is to pursuade me to go ahead with the repair (replace the BC1). I can't believe they were charging me that much. Can anyone tell me how to get rid of that white powdery stuff? AND For future reference how exactly does one get the battery out (it's sooo heavy) For non-S. Thanks. |
| Bit different Issue / Drivers Side Door Won't Open Hi, I was hoping that someone would be able to help. I have read all the threads about the door and the locking mech's not working and how to repair it however I believe my situation is a bit different. When I try to use the key fob to open the door from a locked position, I see the latch move up and down however not enough to unlock the door. This is the first time I have experienced this issue on my 2004 mini. I get a similar reaction when trying to use the key in the door to open it. All other locks on the car are fine however I do notice that the key fob doesn't always respond the first time. For the meantime, would it harm the door to use a slim jim to manually pull the lever arm up (inside the door) to open the door? I also thought that I didn't shut it all the way which could have a similar effect. While pushing on the door, I feel the door give a bit, it seems flush with the body. Appreciate the help ~ S |
| central locking | micky the boy | First Generation Faults & Fixes | 2 | Apr 12th, 2008 09:35 PM |
| Central Locking | gez09 | First Generation Faults & Fixes | 1 | Oct 20th, 2007 12:59 PM |
| Drivers door central locking - won't unlock - will lock | quigger | First Generation Faults & Fixes | 4 | Oct 10th, 2007 05:43 AM |
| Central Locking | RyanDodd | First Generation MINI Cooper | 3 | May 10th, 2005 07:42 PM |
| Central locking but no Central Openning?? | oceanstarBug | First Generation Faults & Fixes | 3 | Mar 19th, 2005 05:02 AM |
