| Can you feel any clunk when you steer or it's vague? Seems like a steering column bro, $750 for it plus labour (around 2 hours) so it's worth a grand. Or..maybe certain parts in the steering mechanism just needs to be lubed up. Usually if it's under warranty, they will lube it up first to see if that sort it out but if not then they will replace it. I have 5 columns replaced in the two MINI's. |
| Fek me.. one huge problem after another.. well im taking up to Trivett tomorrow. My warranty expires on Sunday (timing).. which reminds me i still have to look at the fine print about the warranty i bought. Didnt notice any clunk.. feels more vague than anything else. Before, when u jerk the steering wheel left or right just slightly, the car responds. Where as now, you would have to turn it so that the Mini sign is vertical before any real response. |
| fair chance that's just the ABS self test. sounds like the problem mentioned in the first post is definately the steering column, I've had one replaced and they're the exact symptoms I had. |
i'm not that much of a n00b!!! completely flat garage.every time i feel the ABS self test, i've been going backwards in a straight line, so maybe i just don't know what it should feel like while turning Black MCS |
| Loose suspension / steering | GTT 280 | First Generation MINI Suspension | 14 | May 7th, 2007 08:39 PM |
| Loose steering | GTT 280 | First Generation Faults & Fixes | 9 | Feb 26th, 2006 08:49 AM |
| loose front wheel - help ! | timmyr | First Generation Faults & Fixes | 5 | Jun 20th, 2005 07:51 AM |
| HELP - Loose wheel arch | CARVNIT | First Generation Faults & Fixes | 0 | May 19th, 2005 12:05 AM |
| Loose steering wheel | Miniphobea Teen | First Generation Faults & Fixes | 10 | Jun 11th, 2004 03:48 PM |
