What is Leaking Here? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 1st, 2006, 03:25 AM
ckpoon16's Avatar
Local Time: 03:27 AM
DIY What is Leaking Here?
I was doing an oil change today and I noticed a leak. I looked thru my Mini Cooper Service Manual by Bentley, but was unable to find what the round canister is. Can anyone tell me what is leaking here? Many Thanks.
ID:	116690   Click image for larger version
ID:	116691   Click image for larger version
Old Jun 1st, 2006, 04:19 AM
obehave's Avatar
Mini Mod
Local Time: 07:27 AM
Engine mount.
They're fluid filled. Prone to leaking.
Get it replaced
Old Jun 1st, 2006, 08:27 AM
Root Ginger's Avatar
Amiga 500 to PS3 20 Years
Local Time: 12:27 PM
What he said ^
It was acceptable in the 80's
Old Jun 1st, 2006, 04:48 PM
ckpoon16's Avatar
Thanks a bunch. I will ask them about it today.
Old Aug 18th, 2006, 08:15 AM
1veryhappyowner
United Kingdom View BENJ's Hyper Blue & Black 1st Gen MINI Cooper S Profile
United-Kingdom
Good old MINI2.COM to the rescue, a few clicks and have found exactly what I am looking for. Went out for a walk last night and noticed some oily drops near the front wheel and found I have this exact problem. Is it safe to drive while this is leaking in case it takes a few days before BMW can replace it??
Have many other people had this??
Old May 27th, 2007, 04:13 AM
minigolf's Avatar
Blue is the colour!
Local Time: 10:27 PM
Australia Male View minigolf's Indi Blue & White 1st Gen MINI Cooper S Profile
I've just noticed this problem on my April 04 build MCS. Seeing as my car is out of warranty this may be a DIY fix/repair. Does anybody have any idea as to the cost for the replacement part, and any tips on the DIY repair?
Here's the link to the relevant bits on REALoem (diagram attached below)...
RealOEM.COM * BMW R53 Cooper S ENGINE SUSPENSION
Cheers Liam
ID:	133109   Click image for larger version
Old May 29th, 2007, 09:02 AM
RealOEM.COM BMW R53 Cooper S ENGINE SUSPENSION
Cheers Liam
For costs just phone your local MINI parts department they're normally pretty helpful. For instruction on repair the best idea is to source a Haynes or Bentley manual.
Old May 30th, 2007, 06:26 AM
minigolf's Avatar
Blue is the colour!
Yeah, can do all that (have my own Bentley manual), was just wondering if anyone had any tips. Manuals don't often plan for the "oh *****" moments.
Old May 30th, 2007, 07:41 PM
alski's Avatar
dyno-mite, might not....
Local Time: 11:27 AM
England Male View alski's Classified Ads
, the OEM bit is rubbish, mine went on July 05 mcs, replaced under warranty, asked service manager if this was an upgraded part, as mounts appear to be a common problem but no its the same....
some one in the states has developed a damper, would look at that as an option to help extend the life of the OEM part, on the basis of less movement = longer life?
i know if it goes again out of warranty i will be looking for this guy, also looks better in the engine bay as well, [ not sure if its any better as a solution but can't be worse ]
sure there is a thread here someware, if i find it i will try and post a link
carefree
Old May 31st, 2007, 06:18 AM
DaFlake's Avatar
MMC Member
It is much the same as doing the pulley install. You will need to remove the airbox and then raise the engine to get it off the mount. Once you have it up, you should be able to remove the mount with little effort.
I have a Shoe damper and love it.
Old May 31st, 2007, 07:07 AM
Shoe Damper???
What's that then?
Old May 31st, 2007, 11:51 AM
DaFlake's Avatar
MMC Member
Simply MINI
MINI COOPER :: North American Motoring - Engine Dampers + Early Model Brackets in stock! Red, Blue, Silver Available!
The guys name is Shoe....
Old May 31st, 2007, 01:02 PM
Ah cool, Yes seen those before and was considering getting one. Didn't realise they were known as Shoe Dampers.
I was half imagining someone cutting up a pair of Nike Air Max or something
Old May 31st, 2007, 01:04 PM
DaFlake's Avatar
MMC Member
, most of the time the are referred as LOF dampers after his online name.
  #15 (permalink)
Old Jun 15th, 2007, 06:46 AM
minigolf's Avatar
Blue is the colour!
Cheers Liam
The dealer is going to supply me a new part for FREE (RRP is AU$153) if I cover the labour costs AU$75. Pretty happy with that given my car is almost 1 year out of warranty.
Leaking Radiator wmcblob59 First Generation Faults & Fixes 6 May 30th, 2006 09:20 PM
Leaking Boot Richard22b First Generation Faults & Fixes 9 Dec 13th, 2005 02:56 PM
Leaking One Ribena* First Generation MINI One 60 Mar 7th, 2004 04:43 PM
is mini leaking teddy First Generation Faults & Fixes 2 Oct 29th, 2003 06:29 PM
Leaking Problem John Davies First Generation Faults & Fixes 5 Oct 2nd, 2003 11:55 PM
