| well, just been in and they've stuck a cable tie on it... I've got a feeling that isn't going to solve the problem long term. But hey, I got Mini washed for my hassle. "It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road."--- Author Unknown |
lost windscreen washer fluid couldn't believe it. I poured 1 litre of windscreen washer fluid into the filler cap to see it pour out of the wing drain by the drivers door. What a swizz! Thats what happens if you use cheap materials in important and inaccessible areas. Clearly the tank is holed or the pipe has fffff fallen off. ffff flippinn L less than 1000 miles on the clock too |
| Bonnet / Rear Windscreen Washer / Water in Boot / Steam from Radiator | 1963_1071_COOPER_S | First Generation Faults & Fixes | 4 | Sep 2nd, 2008 08:26 PM |
| Windscreen Washer Failure | bards | First Generation Faults & Fixes | 3 | Apr 18th, 2006 04:30 PM |
| Windscreen washer fluid in wrong place | benjacobs25 | First Generation Faults & Fixes | 25 | Dec 27th, 2005 04:09 PM |
| Windscreen Washer fluid level warning light | Daniel | First Generation Interior & Ice | 21 | May 31st, 2003 04:23 AM |
| Larger Windscreen Washer Fluid Reservoir??? | GMINI | First Generation Faults & Fixes | 2 | Jan 31st, 2003 08:37 PM |
