(MCS) Problem: Engine Fan Stays On - MINI Cooper Forum
LinkBack Thread Tools Rating: Thread Rating: 5 votes, 5.00 average.
post #1 of 30 (permalink) Old Jun 4th, 2006, 07:59 PM Thread Starter
Carbon Fibre *drools*
David_MCS's Avatar
Local Time: 03:49 AM
United Kingdom Male View David_MCS's Dark Silver & Black 1st Gen MINI Cooper S Profile View David_MCS's Classified Ads
Send a message via MSN to David_MCS
United-Kingdom (MCS) Problem: Engine Fan Stays On
Hey Everyone.
I'm a very recent MCS Owner and i have a bit of a problem.
My engine radiator fan stays on. Not just for 5/10/15 mins.. It stays on constantly no matter what the temp of the engine is.
When i unplug the connector, it obviously turns off. When i plug it back in its back on instantly.
Also, when i disconnect the battery, and connect it back up.. it starts the fan straight back up..
I understand the fan is ECU controlled, and have read on the forums that disconnecting the batterie for 30+ mins should reset it.
Can anyone suggest any fixes for the problem? And roughly how much the part will cost.
Thank you in advanced for any help.
-David
David_MCS is offline
post #2 of 30 (permalink) Old Jun 4th, 2006, 09:48 PM Thread Starter
David_MCS's Avatar
United-Kingdom Update..
Disconnected the battery for an hour, reconnected and as you could of guessed.. fan came straight back on without the car even started.
I understand that after 2003 they changed they way that the radiator fan system works, and at some TLC services they are changing pre-2003 MCS's to the new system.
I still have my TLC book with 1 voucher left, is there any possiblity my local Mini Garage will fix/change the problem part?
-David
post #3 of 30 (permalink) Old Jun 5th, 2006, 02:25 PM Thread Starter
David_MCS's Avatar
Anyone know what part i should be ordering/replacing?
-David
post #4 of 30 (permalink) Old Jun 6th, 2006, 09:25 AM Thread Starter
David_MCS's Avatar
All fixed Nothing a sharp nudge couldn't fix..
post #5 of 30 (permalink) Old Jun 6th, 2006, 10:23 AM
Prowse's Avatar
United Kingdom Male View Prowse's Astro Black & Body Color 2nd Gen MINI John Cooper Works Profile
Send a message via MSN to Prowse Send a message via Skype™ to Prowse
Er, just out of interest, what did you nudge?
Prowse is offline
post #6 of 30 (permalink) Old Jun 6th, 2006, 04:24 PM
Local Time: 04:49 AM
United Kingdom View GRSmotorsport's Classified Ads
Send a message via MSN to GRSmotorsport
Right, I had the same problem, ended up having to replace the fan unit completely .
Below are pictures of the part that cause's the problem. You can't buy this part separately, I believe it regulates the speed of the fan.... You can't see this part as its tucked away
Graham
GRSmotorsport is offline
post #7 of 30 (permalink) Old Jun 6th, 2006, 06:31 PM
mikeythemini's Avatar
I had the same problem - sharp tap in the centre of the fan cowl (by the above module) sorted it.
The dealer fitted a new assembly & told me the car was ready, when I got there it was in bits they said it didn't cure it. After another day they said the air con system had too much gas in it !!!! never heard of a car gaining gas over the course of a year
mikeythemini is offline
post #8 of 30 (permalink) Old Jun 6th, 2006, 07:46 PM Thread Starter
David_MCS's Avatar
After unplugging the fan, follow the radiator accross to the left while looking at the fan. When you get the end of the fan, give a little tap with your fist to the radiator.
Plug the fan back in, everything works fine
-David
post #9 of 30 (permalink) Old Mar 18th, 2007, 08:54 AM
Local Time: 01:49 PM
Australia
-David
Thanks David......this worked a treat, there must be an underlying problem though.....shouldn't have to hit something to get it to work properly....for now it's a quick fix, so i THANK YOU very much.
I do have one qustion for you though.....how did you work out where to tap??
Cath
scruffy1806 is offline
post #10 of 30 (permalink) Old Mar 18th, 2007, 09:46 PM
a.k.a. BrainRush
brainycheddar's Avatar
Local Time: 08:49 PM
United States Male
this happened to me once on the way to school, it was raining, and I ended up with a dead battery after 3hrs. I had to call the campus police to get a jump start. but that was the only time it happened to me. so I know, where is the plug to the radiator fan?
Mods: MiniMania CAI and 15% pulley, Racing Brake front rotors, EBC Green Stuff front pads, ALTA 19mm anti-roll bar
brainycheddar is offline
post #11 of 30 (permalink) Old Mar 19th, 2007, 12:50 AM
Australia
On an australian mini, plug for the fan is on the right hand side of the radiator as you look at the engine, it's a biggish plug just under/on the edge of the cowling.
post #12 of 30 (permalink) Old Nov 7th, 2008, 03:37 AM
Local Time: 10:49 PM
Thanks for the fix, I'm off to try it. In a pinch you can always pull the 50 amp fuse to shut the fan off. The fan relay will not do the trick.
IMAMINI is offline
post #13 of 30 (permalink) Old Dec 13th, 2008, 05:27 PM
Local Time: 11:49 PM
Canada
It Works!!!
A tap at the black rectagular box behind the radiator did the trick!!!
Amazing!!! Thanks for the tip mate!
PogiPaul is offline
post #14 of 30 (permalink) Old May 9th, 2009, 11:47 PM
It really does work!
Thanks to all for this thread. Rapping on the cowling at the control box stopped the fan. Now to get the component replaced.
Mainer is offline
post #15 of 30 (permalink) Old May 10th, 2009, 04:47 AM
Menace Motorsport
Australia
That big green unit controles fan speed 2. You will also find a relay in there. The green thing is just a big resisitor. In the plug you will have a constant power (allows the fan to be opperated with the ignition is off) The other large wire is the switched wire from the fan control relay. The other smaller wire is the signal wire to activate the relay when the eng is switched on. The relay is a 87 and 87a type and commanly fails burning out and causing the fan to run constantly that is why hitting them turns them off. I will dig up a wiring digram for it as iv seen many minis with this problem.
Putsy is offline
  LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-faults-fixes/118392-mcs-problem-engine-fan-stays.html
Posted By For Type Date
FAULTS AND FIXES on MINI2 - Fuel For Your MINI Obsession - MINI Cooper - S - One - Diesel - Works - Cabrio | BoardReader This thread Refback Dec 21st, 2008 11:26 AM
Engine knocking/oil level problem... MikeJS First Generation MINI Cooper 0 Sep 29th, 2013 01:57 PM
2003 r53 fan problem.. Will.i.am First Generation Faults & Fixes 0 Mar 5th, 2013 05:30 PM
Another MCS clutch problem leighMCS Maintenance & MINI Care 2 Feb 8th, 2013 08:52 PM
Big engine problem r53? piggly First Generation Faults & Fixes 13 Oct 26th, 2012 03:26 PM
worried about my mcs 05 water temperature, how do i test the fan? jamie m First Generation Faults & Fixes 5 Oct 22nd, 2012 06:17 AM
