Scraping Noise from Left or Centre at Low Speed Chaps, I get a kind of scraping noise from the front (more to the left) at low speeds. It seems much worse when turning left and vanishes when turning right. Once I'm off and going it vanishes. A friend of mine thought it may be tyre pressure related (I'd over inflated accidently). It change in pressure did make a difference for a bit but it came back. Can anyone help? Last edited by Stone Rose; Jun 19th, 2006 at 07:55 PM. |
| Hi Stone Rose,if your running Goodyear 16" runflats its likely it will be the tyres,The remedy is to split the bead and reseal the tyre-with use the Goodyear tyres move on their bead against the wheel rim which causes the rubbing noise-usually goes away with speed |
Chaps, Thanks for your replies. For the record the sound has now gone. The solution: Replaced front two, broke the beading on the rears and lubricated. Re-inflated and the noise has gone. Happy days! Cheers SR |
| Low speed rattle from front right?? | rntheald | First Generation Faults & Fixes | 15 | Jun 13th, 2006 03:49 PM |
| Noise comming from centre off dash | stephen orford | First Generation Faults & Fixes | 4 | Nov 4th, 2005 09:33 AM |
| shaking at low speed | sketcher | First Generation Faults & Fixes | 2 | Oct 1st, 2003 05:54 PM |
| Scraping noise... | davejenkins | First Generation Faults & Fixes | 9 | Aug 5th, 2003 06:37 PM |
| Very low creaking sound coming from left, rear | GregF | First Generation Faults & Fixes | 0 | Jan 12th, 2003 11:46 PM |
