A/C + Wind Noise - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 23rd, 2006, 02:22 PM
burns863's Avatar
The Muffin Man
Local Time: 10:25 AM
A/C + Wind Noise
Hi Mini2'ers! Iv searched the forum for this problem but cant find exactly what i need to know The other day i was driving down the motorway, with the aircon off. The air vents on the dash were closed, but there was a lot of wind noise coming through the vent on top of the speedo, plus some cold air (last setting on the climate control when it was on was 'Lo'). When i opened the vents on the dash there was cold air coming out of them, and the wind noise seemed to die down. Think that it was cos it was spread through more than 1 vent. I eventually got a bit hot and decided to turn the air con n anyway. There was wind noise again untill i switched on the "recirculate" setting. When i next decided to turn off the air con, the wind noise stopped coming through the vent. I am guessing that this is because the recirculate thing was on before i switched the a/c off? Now it seems that I get wind noise everynow and then with the air con off on the motorway. Its starting to annoy me . Its definitly through the air vent! Is this just due to not having the recirculate button on all the time? Also, any ideas why that one off time there was quite a lot of cold air coming from my vents even with the aircon off?
Old Jun 24th, 2006, 07:45 AM
burns863's Avatar
The Muffin Man
update, there seems to be a constant flow f air through the vents when i am on the motorway. It feels like the air con is turned on and on its lowest setting, when it is actually turned off! pls can anyone help?
Old Jun 26th, 2006, 04:44 AM
Send a message via MSN to Yoda
Local Time: 05:25 PM
Thailand Male
I'm not sure with this answer for the facelift. But for prefac-lifted if you turn off the air-con with off button. There will be an airflow from outside into the cabin. You have to turn off the aircon by pressing the fan level button till it's turned off. But there still is LED light on the dial of the air con (In my case it's auto aircon)
MCS JCW Dark Silver/Black
Old Jun 26th, 2006, 02:56 PM
burns863's Avatar
The Muffin Man
cheers mate believe it or not i actually found this out yesterday , i only accidently turned it off using the fan- button, and realised i ahad solved my own problem I too have auto air con on the pre facelift! Thanks a lot for your reply
Wind Noise popey Second Generation Faults & Fixes 69 Jan 2nd, 2009 08:36 PM
Wind Noise?? KostaLot First Generation Faults & Fixes 3 Nov 23rd, 2006 01:06 AM
Wind Noise Aitchy First Generation MINI Cooper 7 Sep 10th, 2004 09:56 AM
Road and wind noise Lylej First Generation MINI Cooper 11 Aug 29th, 2004 01:07 AM
Wind Noise swil00 First Generation Faults & Fixes 5 Aug 10th, 2002 12:17 PM
