How do I tell if the head gasket is gone??? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 2nd, 2006, 03:09 PM
wilmanlee's Avatar
Newbie Adventure
Send a message via MSN to wilmanlee
Local Time: 11:26 AM
Hi,
Checked my Coolant bottle last night and to find that its well below the Min!!!
I know this is a common problem with the coolant bottle on Mini's
I basically want to determine if its the head gasket that is leaking too?....
The damm car is also out of warranty so any ideas on cost???
Thanks in advance everyone.
Wil
Old Jul 2nd, 2006, 03:48 PM
JG.26's Avatar
United Kingdom Male View JG.26's Pure Silver & Black 1st Gen MINI Cooper S Profile
You will lose some coolant through evaporation over time, have topped mine up on a couple of occasions. If your head gasket has gone then you will get water in your oil. Check the oil on the dipstick or inside the filler cap. If the oil has a white mayonaise appearance then you have water in it. Also if your head gasket has gone you can get excessive white smoke from the exhaust,
hope that helps
Old Jul 2nd, 2006, 04:15 PM
wilmanlee's Avatar
Newbie Adventure
Many thanks for the advice,
Just seems like the coolant tank is leaking as there is signs of it on the outside.
Checked oil which seems fine.
Going in to Mini tmw for service so will have them to double check for me.
Old Jul 2nd, 2006, 06:34 PM
JG.26's Avatar
No probs, I think there were problems with earlier coolant tanks leaking around it's seam, would rather it be the tank than the head gasket
Old Jul 2nd, 2006, 07:22 PM
wilmanlee's Avatar
Newbie Adventure
Me think the same too......what you think the cost of it will be to change the coolant tank.
Old Jul 2nd, 2006, 07:51 PM
JG.26's Avatar
I can't imagine a new plastic tank would be more than a tenner, it's the labour charge to change it over if you get BMW to do the work. You could always buy the tank and get an independant to change it over for you, or do it yourself if your feeling brave
Old Jul 2nd, 2006, 09:21 PM
wilmanlee's Avatar
Newbie Adventure
Changing the tank shouldnt be too difficult....im confident in that respect. But its the draining of the coolant im not sure about.
Do you or anyone else know how to drain the system??
Old Jul 2nd, 2006, 09:36 PM
JG.26's Avatar
Sorry not on the MINI I don't, but was easy enough on a Mazda 323 I once had, just undo the drain tap, bottom of radiator, I think I remember getting a hose and flushing the radiator out from the top filler neck, put the heater onto hot and filled back up to about 3/4 and then started engine and filled upto normal level, 50/50 coolant and distilled water mix. Just need to watch for any air in the sysyem. Probably totally different for the MINI .....anyone else?
Old Jul 3rd, 2006, 12:18 PM
wilmanlee's Avatar
Newbie Adventure
Just come back from Mini after having 2nd oil service and brake fluid change. Turns out it was the coolant bottle that is leaking. Changed it for a new one, costing £50 supply and fitted with coolant!. Alot cheaper than expected considering they quoted me £70 for just a coolant change.
Will be keeping a eye on it now jsut to make sure its nothing else that is leaking!.
Wil
Old Jul 3rd, 2006, 08:20 PM
JG.26's Avatar
Wil
Cool, glad you got it all sorted out last thing you need is no coolant on a day like today
Old Jul 3rd, 2006, 10:24 PM
Local Time: 06:26 AM
United States Male
when you start breathin thru your neck ...your head gasket's gone ,.
Old Jul 3rd, 2006, 10:36 PM
wilmanlee's Avatar
Newbie Adventure
My knowledge of engine is not that great........what do u mean by the above??...
Head Gasket leaking? Tara&Paul First Generation Faults & Fixes 2 Aug 28th, 2007 12:45 AM
Head Gasket scrob First Generation Faults & Fixes 10 Dec 14th, 2006 12:13 PM
Head Gasket Prices? kustomisedminibadges First Generation Faults & Fixes 0 Oct 21st, 2006 03:52 PM
head gasket / knackered head arrgh welsh_willo First Generation Faults & Fixes 0 Feb 3rd, 2006 09:38 PM
Thinner head gasket for the MC cobus First Generation MINI Tuning 0 Nov 29th, 2004 05:45 PM
