Electric window stopped working - Page 2 - MINI Cooper Forum - MINI2 Mini Cooper Forums
  #16 (permalink)
Old Jul 10th, 2011, 12:40 AM
Local Time: 03:26 AM
Canada
Gave the door a whack and window started working again. At least it is not the motor or controller. It sounds a little laboured so when i open it up I will lube everything up and see how it goes.
  #17 (permalink)
Old Jul 10th, 2011, 07:46 PM
Canada
What is the inside problem?
OK I wacked the door and the window started working again. What does anyone think is going on? Is it shaking the armature and brushes? Is the bearing worn and so the armature is out of alignment?
  #18 (permalink)
Old Jul 11th, 2011, 11:10 PM
cristo's Avatar
BLIKSEM (my brg/brg mc)
Local Time: 05:26 AM
United States Male View cristo's British Racing Green & Body Color 1st Gen MINI Cooper Profile
It is the motor. You're knocking dust and dirt from the brushes and re-establishing enough
electrical contact for it to work again.
Mine's been like this on the passenger side for 2-3 years now - mainly acts up in the Summer.
  #19 (permalink)
Old Aug 16th, 2011, 10:33 AM
Local Time: 11:26 AM
Cyprus
just save myself a new motor for my sons mini . Yes , a few punches just above the speaker and offcourse holding the switch for 20 seconds made the window work. Thank you guys !
  #20 (permalink)
Old Sep 7th, 2011, 03:27 PM
cristo's Avatar
Mine still responds to the persuasive thunk to the door card.
Only problem is that it finally shifted the magnet assembly the woofer, so now the voice coil is pinched and
the cone doesn't move at all.
Nothing that $60 + $15 shipping to PolkAudio for a replacement driver can't fix, however
(I have the Polk db6501 components in the front doors).
  #21 (permalink)
Old Sep 7th, 2011, 05:45 PM
MiniAcadie's Avatar
Crazy Canuck
Local Time: 07:26 AM
Canada Male
Thumbs up Waaaapaaaaaaaaa!!!!
My driver's window got stuck open once and I tried the punch method. Worked great. Haven't had a problem since.
So when in doubt
WAAAAAAPAAAAAAAA!!
  #22 (permalink)
Old Sep 12th, 2011, 01:17 AM
Local Time: 08:26 PM
Australia
Hi all
Recently joined the forum and wanted to say thanks
I recently bought a 2003 Cooper S and when I took it for a test drive i noticed that the passenger side window was stuck in the closed position. I informed the dealer and when I collected it later that day he reported that he had fixed it (Just a fuse he said). The window was working so I took delivery and it was fine for the last two weeks.
Yesterday when I went to move the window all I got was a click and no movement. I read this post and thought OK give the door card a whack and see what happens. Sure enough the window worked.
The car is under a 3 month warranty so I will take it back and see if they will spring for a new power winder.
Thanks again to all
Tsmsoccer
  #23 (permalink)
Old Sep 28th, 2011, 10:21 AM
Local Time: 10:26 AM
United-Kingdom Electric windon
I noticed that my window didnt go down, tried the banging on the door a go took a few whacks in various places and it worked, wish it was that simple when the gearbox went after 3 days of getting the car,
Thanks for the advice worth the weight in gold.
  #24 (permalink)
Old Dec 2nd, 2011, 09:10 AM
United Kingdom Female
Hi guys, i have the same problem that my Mini's driver's window won't go up/down. I discovered it last night when leaving work, tried opening the door and the window was still in the 'up' position. Tried the electric window switch but still nothing, it also isn't making the clicking sound it usually does. So I’m now having to climb in/out via the passenger side- not ideal!
However the difference with my car is that it was broken into earlier this year, via the use of a crowbar to prize open and smash the driver's window to gain entry.
At the time i called the windscreen repair company provided via my insurance company, but after they replaced the window i was left with a huge gap all the way around the door frame.
So i then got a mechanic to look at it and he said the door mechanism had been damaged during the window being smashed. He managed to get the window to sit flush into the frame, however it's never been quite right- very shaky/unstable compared to the passenger window & doesn't always go 'up' into the frame 1st time when using the electric window switch.
I really don't want to take it to a Mini dealership, as I’m guessing they'll charge me a small fortune. However I have no mechanical skills myself and don't know anyone who does, so i'll need to seek some professional help.
Has anyone got any idea how serious this problem could be? Any help would be greatly appreciated.
(FYI: I have a 2006 55reg Mini Cooper 1.6)
  #25 (permalink)
Old Dec 12th, 2011, 08:26 PM
yes just gave mine a whack above the speaker and it worked
cheers
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Aircon Stopped Working djtex Second Generation Faults & Fixes 2 Jun 30th, 2009 03:20 AM
Bluetooth stopped working Coffeeman Second Generation Faults & Fixes 2 Oct 25th, 2007 04:31 PM
Remote stopped working Lister First Generation Faults & Fixes 0 Jun 15th, 2007 11:22 PM
Passenger side window stopped working... tenderidol First Generation Faults & Fixes 2 Oct 29th, 2005 06:47 PM
My tachometer has stopped working! megster First Generation Faults & Fixes 3 Nov 13th, 2002 05:36 PM
