| A/C Condenser fan Just trying to work out how long the condenser fan should run for when a/c is on. The high pressure side of my a/c is running at between 15 to 20 bar. Low pressure is 2 bar. Ambient temp is 25 C. The condenser fan runs with a/c for about 5 seconds then fan cuts out. The pressure goes back up to 20 bar and the fan cuts in again. The high pressure is too high and is causing poor cooling of the condenser and thus not so cool air at the vents. I always thought the fan should run with the a/c all the time. Anyone know if their condenser fan runs all the time with the a/c on. 2002 Cooper. Thanks. |
| Damaged aircond line between condenser and evap..$1100...plus more problems! | Tom F. | First Generation Faults & Fixes | 0 | Jul 7th, 2007 08:01 PM |
| Condenser fan problem ????? | Lucas63 | First Generation Faults & Fixes | 1 | Jan 11th, 2007 09:02 PM |
| PS fan, main fan | eddieboyII | First Generation MINI Cooper S | 1 | Jun 30th, 2004 05:16 AM |
| Suggestions for OEM radiator and a/c condenser? | CooperCooper | First Generation Faults & Fixes | 0 | Feb 20th, 2004 11:17 PM |
