Aircon? water patch and tube ? *pic* - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 25th, 2006, 08:37 AM
pardonator's Avatar
Send a message via Skype™ to pardonator
Local Time: 10:10 PM
United Kingdom Male View pardonator's Classified Ads
I'm pretty sure this is normal, hopeing really
Last few days i've noticed small puddles of water under my car, underneath the center of the dash area. I searched on the forum here and im 99% sure its just water from the aircon, which I believe is normal. But today, I put the aircon on and then looked underneath and noticed a tube and litterally a stream of water came out, bit like a cold water dispenser It only lasted 2-3 seconds but it didn't seem right. Could it be just flushing out what water has melted? condensed etc from the day before? Is my mini releaving itself?
Does anyone else have this tube? You can see it more or less in line with the centre dash underneath.
Cooper S Hyper Blue - GTT/GRS/Speedline/KW
Old Jul 25th, 2006, 12:38 PM
Jon Chalk's Avatar
Cooperama? Who's he?
Local Time: 11:10 PM
United Kingdom Male View Jon Chalk's Black-Eye Purple & Black 1st Gen MINI Cooper Profile
Haven't looked under mine, but would think it would be to ensure that the condensed water from the aircon is safely dropped under the car, not splashed around when on the move. I think you're pretty safe to assume it's the aircon bleeding off any water that may have built up on the condenser since it was las turned off (the condenser will stay colder than surrounding air for a little while until it warms up to ambient temp., once car has been turned off)
Old Jul 25th, 2006, 02:36 PM
Root Ginger's Avatar
Amiga 500 to PS3 20 Years
This is fine and what you suspect it is.
If I pop out in my MINI and then return a little later I can actually see a little puddle under my car and then a little trail of water where I've pulled away. It is surprising how much moisture condenses.
It would be nice if the water was reused in some way rather than dumped on the ground though.
It was acceptable in the 80's
Old Jul 25th, 2006, 09:52 PM
pardonator's Avatar
Phew thanks for confirming
As for reusing the water, a nice dispenser on the dashboard would be quite nice
Water damage to engine - air intake susceptible to sucking in water stevesok First Generation Faults & Fixes 83 Jul 25th, 2007 04:58 PM
Cooler tube and some shiny bits(Updated pic) obehave First Generation MINI Tuning 19 Jun 18th, 2006 03:22 AM
What is this tube for ???? fone First Generation MINI Tuning 10 May 15th, 2006 06:14 AM
