| clutch (how many miles?) pressure plate or sorry input splines gone ?it's weird though i've never had a clutch that couldn't limp home in a lower gear. so broken pressure plate springs or something ... do you do alot of really hard launches? |
| Nope, not even my car, it's owned by my wife's company. It has less than 30k miles on it and it's hardly been driven at all since around December last year! It is a bit crap mind you. First we lost all forward gears, then after I'd parked up I wondered if I'd get anything out of reverse. I did. A couple of feet, then that lost everything too. |
| Thing is I've had clutches and gearboxes go in the past on much older cars, the clutch was a much more gradual process, whereas the gearbox was a quick and painful process (I was moving house at the time and it was full of my stuff!). |
| The fact that you had reverse for a second makes me think the Gear box itself has gone, but even with dealing with these cars everyday it can still sometimes be difficult to tell without pulling the car apart |
| Sorry to hear that Paul, does sound like the clutch if you suddenly lost drive, would a gear box fail that suddenly or would you get more of a warning? not sure? at least if it's a company car they will foot the repair bill. I'm glad now I took a new warranty out on Sunday with Warranty Direct, it's cost me £260 for 12 months and thats with choosing a BMW garage to do repairs whereas it's £219 if you go to a non BMW garage, good value I think as BMW wanted £560 per year, which is alot. I guess just replacing the clutch is expensive as it's a gearbox out jobbie Hope you get it sorted |
| Paul, With the engine off, depress clutch pedal fully ,engage first gear then with foot still on clutch pedal ,start the car. If the clutch is faulty & dragging (for whatever reason), the car will move forward on the starter. Ensure you have a clear space in front of you & be ready to turn the key off again. !! BNest Regards Roland GTT |
| Hi Paul,it unfortunately sounds like the gearbox has given up-the differential shears its drive resulting in no drive at all-have seen this happen to a few Mini"s!There are some companies that will refurb and repair the gearbox otherwise its a new gearbox,best wishes,Anthony. |
| Yes sorry to tell you Paul its the diff , we have seen a few of these recently the gearbox problems start with a noise then some difficulty with 1st and 2nd selections ,the clutch starts with a little stiffness in operation then a slight drop in the point of engagement then the noise then fails. |
| Wow. I believe you guys, it is just that I have not seen a failed gearbox since I quit working on air cooled VW dunebuggys. And they only failed after a couple of hundred thousand miles. Learn something new every day. |
| Broken gearbox for manual MC | Hubert | First Generation Faults & Fixes | 26 | Feb 20th, 2005 06:06 PM |
| Gearbox broken | Maxx | First Generation Faults & Fixes | 6 | Jul 16th, 2004 09:54 AM |
| Broken Gearbox | theminiv | First Generation Faults & Fixes | 5 | Sep 27th, 2003 01:41 PM |
| Have I Broken my Gearbox? | alreet | First Generation MINI Tuning | 2 | Jun 13th, 2003 09:49 AM |
