Seat reclining problem - MINI Cooper Forum
post #1 of 4 (permalink) Old Aug 1st, 2002, 07:57 PM Thread Starter
Cinimod's Avatar
Local Time: 06:24 AM
England
Send a message via MSN to Cinimod
I have a problem with the drivers seat in my January 2002 mini cooper.
If you recline the seat to lie back and relax, you sometimes have a VERY hard time getting it back up.
Also if you have reclined it a little and put it back up, the forward release mechanism gets jammed and it is hard to get the passengers out from the back!
Anyone else found that?
Cinimod is offline
post #2 of 4 (permalink) Old Aug 1st, 2002, 08:14 PM
MINI2 No.1
Paul's Avatar
Quoted: 1 Post(s)
England Male
Send a message via Skype™ to Paul
This is one of the most discussed, how can I put it... 'issues' with the new MINI interior!
Try searching for 'seat mechanism' or 'seat jammed' using the 'search' button up above.
You'll learn you're far from the only one. Whether that will make you feel better for knowing your not alone, or more frustrated at the design, depends on your outlook I guess!
Paul is offline
post #3 of 4 (permalink) Old Aug 2nd, 2002, 08:06 AM
If you have such problems with your seat, I suggest that you get in touch with your deal and say to them you have mechanical problems with the seat, they should replace it! Apparantly there has been some manufacturing faults. They don't seem to advertise these problems, it up to the owner to complain about it then the fix it!
minky is offline
post #4 of 4 (permalink) Old Aug 2nd, 2002, 08:46 AM Thread Starter
Cinimod's Avatar
England
We will have to see...
Waiting to see what they say when I take it in on the 17th for the gear cable...
Cinimod is offline
seat position after tilting romiloned Maintenance & MINI Care 2 Apr 8th, 2013 06:22 PM
Mini problem - please help!! HelpMe General Discussion 13 Jan 18th, 2013 09:00 PM
Child Seat problem COOPERBLUE General Discussion 0 Jan 14th, 2013 07:46 PM
leather seat fault warranty advice mtramsay Second Generation Faults & Fixes 2 Nov 6th, 2012 08:18 PM
Unable to remove rear seat in '03 base Doorothie First Generation Faults & Fixes 0 Aug 23rd, 2012 07:23 PM
