Strange fault with Central locking while driving - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 5th, 2006, 05:59 PM
M11NYL's Avatar
obsessive
Send a message via AIM to M11NYL
Local Time: 11:26 AM
United Kingdom Male View M11NYL's Electric Blue & White 1st Gen MINI Cooper S Profile
I have a MCS and was driving to town today and for some reason my door automatically locked for no reason, ( i know about the safety feature but mine is not active) so i un locked them via the switch under the radio, then they locked again right after.
so i tried again and it did the same, so i carried on driving and left them locked, after 5 mins i tried again and they opened fine and stayued like it for a couple of mins then locked again.
this continued for the whole journey, the car locked fine after turning the engine off but it just seens strage to do this while driving.
has anyone else had this problem
Old Aug 5th, 2006, 06:06 PM
Root Ginger's Avatar
Amiga 500 to PS3 20 Years
Possible BCU gremlins I think.
If it continues to do it try a software reset or disconnect the battery for 5 mins (both achieve the same thing).
It was acceptable in the 80's
Old Aug 5th, 2006, 06:17 PM
M11NYL's Avatar
obsessive
BCU DO YOU MEAN ECU
Old Aug 5th, 2006, 06:49 PM
Paul's Avatar
MINI2 No.1
Local Time: 10:26 AM
England Male
BCU is "body control unit".
Old Aug 6th, 2006, 08:58 PM
M11NYL's Avatar
obsessive
Thanks for that ill see how it goes tomorrow and if the probis still there ill look in the haynes manual for the reset button if i cant find it, ill have to did out the old tool kit and blow off the dust and disconnect the battery
Old Aug 7th, 2006, 06:47 AM
If you look in the FAQ section, Interior and In Car Entertainment and look at How to show RPM, Fuel Level, Speed and more on your Odometer Digital Display. There is an option there for software reset. This is not in the Haynes manual. In fact IMO the Haynes manual is not very good. There's a lot of missing details in the manual.
Old Aug 10th, 2006, 01:57 PM
Sounds a lot like a known issue about earlier Minis. Maybe this is the case in your Mini, too.
Mine (MFG date 10/2001) had a similar problem: the doors locked and unlocked during driving. Sometimes faster sometimes slower. Very annoying!
The BCU was exchanged and covered against moisture. In fact they put a little Goretex hood over it and fix it with self-sealing waterproof tape. This little hood even has a BMW part code - so the issue is well known.
As I heard, this failure was rather well known at the time when I made the complaint to my dealer.
Just give it a try and maybe do it rather sooner than later: my dealer then congratulated me that the sunroof was not affected and also the window openers. On other cars they all of a sudden had a life of their own. Tended to happen during rain when the moisture reached the BCU
Good luck!
Wolfgang
Wolfgang Bruno Tarnofsky
central locking micky the boy First Generation Faults & Fixes 2 Apr 12th, 2008 09:35 PM
central locking fault and window wont go down on passenger side - please help?? slaterminn First Generation MINI One 2 Jul 27th, 2007 07:30 PM
Central Locking RyanDodd First Generation MINI Cooper 3 May 10th, 2005 07:42 PM
Central locking but no Central Openning?? oceanstarBug First Generation Faults & Fixes 3 Mar 19th, 2005 05:02 AM
Central locking coin First Generation MINI One 12 Mar 1st, 2003 07:05 PM
