Mini One D Head Gasket Blown - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 9th, 2006, 04:55 PM
Local Time: 11:26 AM
Ireland
Just returned from my dealer with the bad news that the head gasket is blown on my 04 one D. It initially overheated last week when I was informed that it was a cracked expansion tank which was replaced under warranty but the next day it overheated again and have been informed that as I suspected in the first place the head gasket has blown.I am concerned that they may be other damage as a result. So has anyone had a similar experience and did it have a successful conclusion.Is replacing the head gasket just dealing with symptom rather than the cause??
Old Aug 9th, 2006, 05:13 PM
ALD0's Avatar
Hello,
Welcome to MINI2, not so good first post though?!
There is not normally any problems reported with these engines as it's a Toyota unit tweeked by BMW.
Has the car had any performance modification like a engine re-map or chip?
Old Aug 9th, 2006, 05:15 PM
Ireland
No.. standard and had it from new
Old Aug 9th, 2006, 05:36 PM
Root Ginger's Avatar
Amiga 500 to PS3 20 Years
Head gasket should not go without something causing it unless it is high mileage.
This engine is very reliable so I'm surprised that this has happened. The cause needs to be found.
It was acceptable in the 80's
Old Aug 10th, 2006, 09:23 AM
sjrainsford's Avatar
Stu
Send a message via MSN to sjrainsford
The headgasket can go in a situation like yours if the engine has overheated in the past.
At the worst case, your engine may not have fully survived the overheat, which may have caused the block or head to warp.
However, it may as said just be that the head gasket has failed due to the overheat which means once replaced you'll be up and running again!
I'm a member of the Toyota owners club and have been for many years, and i'm aware that this engine is pretty much bullet proof normally.
So you just gotta hope these problems are just due to it overheating in the first place.
Best of luck!
Old Nov 17th, 2007, 11:25 PM
Send a message via MSN to Jinkster Send a message via Skype™ to Jinkster
United Kingdom Male View Jinkster's Chili Red & Body Color 1st Gen MINI One Diesel Profile View Jinkster's Classified Ads
how much for a new head gasket - fitted?
Blown head gasket after routine fix Mini Mook First Generation Faults & Fixes 10 Jul 4th, 2008 08:34 AM
Head Gasket scrob First Generation Faults & Fixes 10 Dec 14th, 2006 12:13 PM
How do I tell if the head gasket is gone??? wilmanlee First Generation Faults & Fixes 11 Jul 3rd, 2006 10:36 PM
head gasket / knackered head arrgh welsh_willo First Generation Faults & Fixes 0 Feb 3rd, 2006 09:38 PM
Thinner head gasket for the MC cobus First Generation MINI Tuning 0 Nov 29th, 2004 05:45 PM
