| If it were me, I wouldn't worry about it.
Car engines make noises. Some make more noises than others, but that doesn't mean they are about to fail. |
| UPDATE: I started the car this morning and it made a slight tappety noise for about a second then settled down. So I took it out for a run, parked up and checked the oil after 5 minutes and it all seems to be OK. I think I'll contact the dealer tomorrow and see what they have to say... I'm a bit worried it could develop into something else. ![]() |
| A lot of cars do this, especially ones with hydraulic tappets. Imagine a little plunger that uses oil pressure as a spring. Until the oil pressure builds up, the tappet rattles a bit. It takes a second for the oil to circulate and build pressure in the upper part of the engine and fill the tappet. It's more common to hear the tappets when an incorrect oil has been used, usually a thicker version will take longer to circulate properly and work its way into the tiny oilway in the side of the tappet. A commonly made mistake is when people put a thicker oil in their car thinking it will quieten tappet noise when in fact it will make it louder because its like trying to force treacle through the tiny hole that is the oilway. If i've done a rubbish job of explaining all that, go here instead!: http://www.volvoclub.org.uk/tech/Hyd...ic%20tappet%22 PS i'd like to stress that I have NO involovement with Volvos whatsoever! Blame Google! |
| "Tink" noise from engine? | Cooooooperslad | First Generation Faults & Fixes | 1 | Aug 26th, 2007 12:06 AM |
| Wierd Squeak/Click noise from rear of car when STATIONARY "tink" | Cooooooperslad | First Generation Faults & Fixes | 0 | Aug 25th, 2007 11:14 PM |
| "Popping" "Clinking" noise when my MCS cools down | Minkymoo | First Generation Faults & Fixes | 5 | Oct 3rd, 2006 08:20 AM |
| Engine "staggered" noise | lusomini | First Generation Faults & Fixes | 1 | Jun 22nd, 2004 10:05 AM |
| Does this happen to any other "S" owners??? (exhaust noise trips car alarms) | Rynyin | First Generation MINI Cooper S | 5 | Oct 17th, 2002 04:19 PM |
